JD
Please find info as requested:
The service menu is accessed on the remote by pressing the "i" button and mute at the same time.
to adjust the geometry select option 4, the other options are best left alone. Before you adjust any of the settings be sure to write them all down so that you can return them to the defaults if you cock-up.
You will need to write down the settings for all picture modes, panoramic, regular, 14:9, 16:9, 16:9 subtitle, full.
You should select Panoramic mode first because when altered it changes all the others modes as well, so you need to go into them one by one after, to redo them if needed.
To move between the modes in the service menu press the red button on the remote.
The up and down buttons on the remote moves between the different settings the left and right buttons change the value. Press "OK" to save changes or "i" to go back/exit.
If you change a modes settings save them before moving on to the next mode or the settings return to the previous value.
I would also download the test patterns orbitalzone has posted above as this will help.
Hope everything goes OK, if not you might be getting that plasma a bit earlier
Rob
