Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 29-08-2002, 5:35 PM   #1 (permalink)
screen cleaner
Is there a cheap easy cleaner to clean t.v. screens with? The baby's finger prints are killing me!!!!!!!
woody183 is offline   Reply With Quote
Old 29-08-2002, 7:03 PM   #2 (permalink)
Try Windolene non smear For glass & shiny surfaces . It says on the label it can be used for television screens and vdu's .
It does a great job of cleaning the mess left behind by my 2year old, so I know exactly how you feel
tom
tom-m is offline   Reply With Quote
Old 29-08-2002, 7:15 PM   #3 (permalink)
rct
rct's Avatar
Careful about using any cleaning product on coated glass (anti-static/reflective/glare) as many new TVs do.
Often a purplish refelction means the screen is coated. For these simply use water and kitchen roll. Dry thoroughly with dry kitchen roll. For stubborn marks use a **little** hand soap. And repeat as before.
Screen should then be as good as new!
"In three words I can sum up everything I've learned about life: It goes on." Robert Frost.
Volunteer your PC and fight cancer! http://www.grid.org/projects/cancer/
rct is offline   Reply With Quote
Old 30-08-2002, 8:35 PM   #4 (permalink)
cheers chaps, i'll give it a go
cleaner, screen
