Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 29-07-2002, 7:33 PM   #1 (permalink)
Component video leads
Hello,
I have component video input on my Toshiba 36ZP18Q and will also have the corresponding outputs on my Yelo DVD player (when it arrives).
Are the cables to connect component video specially designed for that purpose? Does one go out and shop for "component video cables"?
Am I right in thinking that component video plus optical digital audio is the best I could achieve between my DVD and TV?
Cheers!
Jules
jules8104 is offline   Reply With Quote
Old 29-07-2002, 7:51 PM   #2 (permalink)
groundy's Avatar
Re: Component video leads
Originally posted by jules8104
Hello,
Yes, you can buy dedicated Component Video Cables. These are made up of three independent 75ohm Coaxial Video Cables, like the type you would see used in single form for Composite Video. If you can't find any Component Video badged cables (not many High Street shops do them), you could just buy 3 Composite Video Cables and plug them into the appropriate sockets on DVD player and TV. It is worth buying good quality ones though.
A good online retailer selling Component Video cables is:
http://www.hificables.co.uk
Yes but the Component Video benefits over RGb depend upon how well the TV or DVD player handles each type of signal. The tosh Component input is very good but I can't comment on the Yelo DVD player. You can always try both Component and RGB Scart and see for yourself. You'll probably find the main benefit of using Component with your setup is that it frees up the Tv's single RGB Scart socket so it can be used by another source.
Paul
groundy is offline   Reply With Quote
Old 29-07-2002, 8:44 PM   #3 (permalink)
Groundy,
Thanks for another great response!
Jules
Old 29-07-2002, 8:53 PM   #4 (permalink)
Just to be sure...
The cables listed at http://www.hificables.co.uk/acatalog...cables_36.html would seem to be what you were talking about (3 identical, individual cables with RCAs at each end) - right?
Thanks!
Jules
Old 29-07-2002, 9:54 PM   #5 (permalink)
groundy's Avatar
Yes, they are a fine set of Component Video Cables .
Paul
component, leads, video
