| Philips flat 21" brighter in the middle of the screen?
New TV just delivered. A Philips 21PT5409.
First thoughts: they don't make 'em like they used to! Build quality is not a patch on an old 21" Philips (though that cost considerably more over a decade ago).
All a bit cheap and plasticky though I guess not too bad for £120.
Picture seems to be OK.
However, even on taking the TV out of the box, I noticed that the centre of the screen appears brighter than the edges.
When actually watching TV it's not noticeable but when you get the plain black screen for a brief second switching between channels, you can see that the centre is a bit brighter than the edges. Same with Ceefax.
And you can see it quite clearly when the set is turned off.
Not a major issue but is this a quirk of the real flat tube or is it a problem that TVs can suffer from?
Thanks.
