Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Philips 21PT5520 CRT doming problem doomer CRT Televisions 2 25-10-2006 10:25 AM
Picture Problem with Philips CRT abspag CRT Televisions 2 14-08-2006 4:41 PM
Philips 28PT4418/05 28" CRT, screen problem Robs Ryans CRT Televisions 1 03-07-2006 8:21 AM
Picture alignment problem on Philips 28" CRT siw CRT Televisions 2 26-12-2005 12:20 PM
Old 08-11-2006, 6:55 PM   #1 (permalink)
Damo121's Avatar
Thanks: Gave 34, Got 5
Philips 32" CRT Problem HELP!
My Philips TV pictures on all channels keeps going a strange purply orange colour, like everything looks washed out.
Any help on a remedy or dianostic would be most appreciated.
Damo
Damo121 is offline   Reply With Quote
Old 08-11-2006, 6:58 PM   #2 (permalink)
Conspicuous Member
Thanks: Gave 4, Got 1,199
Re: Philips 32" CRT Problem HELP!
Not much help, but it sounds like the end to me.
You have got to ask yourself, how old and is it worth fixing. If >6-8 years then I would say not.
Andy98765 is offline   Reply With Quote
Old 08-11-2006, 7:10 PM   #3 (permalink)
Damo121's Avatar
Its about 3yrs old and has an extended warranty, so looks like a workshop job then!
Damo
Old 08-11-2006, 7:28 PM   #4 (permalink)
technospark's Avatar
Thanks: Gave 1, Got 12
try this site:
http://www.comtech2000.co.uk/
tec
technospark is offline   Reply With Quote
Old 08-11-2006, 7:30 PM   #5 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 857
So why are you asking here?
Call the place where you have the extended warranty.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 08-11-2006, 8:13 PM   #6 (permalink)
Damo121's Avatar
Why not
Old 08-11-2006, 8:26 PM   #7 (permalink)
Damo121's Avatar
Originally Posted by technospark View Post
Cheers for this, but my TV is not listed on the menu. Its model #32PW9527.
Damo
Old 08-11-2006, 11:05 PM   #8 (permalink)
Conspicuous Member
JayCee's Avatar
Why not
What are you going to do...it's not as if you can fix it yourself.
JayCee
Old 08-11-2006, 11:30 PM   #9 (permalink)
Thanks: Gave 21, Got 23
Exclamation Re: Philips 32" CRT Problem HELP!
have u checked the leads?
gbmitie
gbmitie is offline   Reply With Quote
Old 09-11-2006, 1:18 PM   #10 (permalink)
Thanks: Gave 82, Got 58
I don't think he knew that until someone *here* told him.
aekostas is offline   Reply With Quote
Old 09-11-2006, 4:14 PM   #11 (permalink)
Damo121's Avatar
If I knew how to fix the problem myself, do you really think that I'd be asking for help and advise.
If you can't help don't bother posting your comments.
Damo
Old 09-11-2006, 4:17 PM   #12 (permalink)
Damo121's Avatar
Spot on! Cheers Mate
Damo
Old 09-11-2006, 6:59 PM   #13 (permalink)
Conspicuous Member
JayCee's Avatar
I'm just trying to understand why you've posted here asking for help when you've already stated that the set is still under an extended warranty...why not just call out the engineer under said warranty and get it fixed?...if you tamper with it yourself you'll invalidate the warranty.
JayCee
crt, philips 32, problem
