Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
DVI to DVI or DVI To HDMI - Watching HD DIVX ON PC? ddr400design LCD Televisions 7 11-08-2006 8:24 PM
DVI-DVI or DVI-HDMI woes?? se30mavrek LCD Televisions 21 19-05-2006 4:04 PM
Old 08-11-2006, 3:00 PM   #1 (permalink)
alpo79
Posts: n/a
DVI and PC IN? Please Help!
I have a Samsung LW26A33WX. It was manufactured November 2004 and bought February 2005. However, I wanted to know if it's possible to put either the official Xbox 360 Component HD cable or VGA cable in either the DVI or PC IN?
As I was hoping to be able to play my games in high definition or am I going to have to fork out hundreds of pounds on a new telly?
Old 08-11-2006, 3:06 PM   #2 (permalink)
rEVILospud's Avatar
Thanks: Gave 48, Got 265
Re: DVI and PC IN? Please Help!
PC input usually means VGA - so thats not a problem.
Also, you can get VGA to DVI adapters, as long as it's DVI-I (which it probably is).
Basically if you get the VGA cable, you have got the 2 above connections available.
SP50 DLP REAR-PRO HDTV ~ STR-DA3200ES AMP
XBOX 360 ELITE ~ PS3 UK BD ~ HD-E1 HD DVD ~ V+ ~ XPS ONE 20
MS 905i - MS 902i's - MS 309i - M3DS's
rEVILospud is offline   Reply With Quote
dvi
