Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Old 03-07-2002, 1:52 PM   #1 (permalink)
Thanks: Gave 2, Got 5
1 rgb scart 2 devices to connect - how?
It's a quiet day at the office so here's another post:-
If you have 1x enabled scart and you have two rgb enabled devices to connect ie. digital cable set top box and games console how do you get them both connected for rgb? Do you have to use a switching device?
Currently have games console on rgb scart - does not work on the other scarts and set top box on scart two.
over to you
thanks
hulkhead is offline   Reply With Quote
Old 03-07-2002, 2:41 PM   #2 (permalink)
DaveP
Posts: n/a
If your digital cable box has a second scart it should provide RGB passthrough. If you've only got one scart socket on it you will need a switch box. They are cheap enough but a PITA to have to keep getting up off the sofa and prssing the button!
DaveP
Old 03-07-2002, 3:31 PM   #3 (permalink)
Squirrel God
Posts: n/a
DaveP
I think you might be able to get ones that auto-switch?
Old 03-07-2002, 9:10 PM   #4 (permalink)
Bal
Thanks: Gave 6, Got 34
You can get auto-switching ones - Quattro+ but seems a waste of £80 if you only have one other source to connect. Better of spending a tenner and getting a manual switch.
Bal
Bal is offline   Reply With Quote
Old 03-07-2002, 9:36 PM   #5 (permalink)
highlanders's Avatar
Thanks: Gave 9, Got 10
I have a scart box, two scart sockets into one scart lead (if that makes any sense). Would that do the job, two rgb inputs going to one scart conected to TV. The only thing is you would have to make sure that you only feed it one input ar a time.
James
highlanders is offline   Reply With Quote
Old 03-07-2002, 11:00 PM   #6 (permalink)
Squirrel God
Posts: n/a
I'd pay £80 if it meant I didn't have to get up off the sofa
connect, devices, rgb, scart
