Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Old 03-07-2002, 1:17 PM   #1 (permalink)
Philips 28PW9617
Is there a volume display on the 9617 which gives a display of volume level when changing volume, if so how do you get it up on screen. Also don't seem to be able to get the set to work from my sky digital remote, have tried reprogramming remote using Philips code of 0081 but no joy. Any advice would be appreciated.
cheers
Arch is offline   Reply With Quote
Old 03-07-2002, 2:31 PM   #2 (permalink)
Thanks: Gave 2, Got 13
I couldn't get the Sky digital remote to work with my 28PW9617 either.
In the end I used it as an excuse to buy a Phillips pronto remote.
Unfotunately I don't have the TV at the moment coz it was doing this
If you find a solution to the Sky Remote I'd be interested as my wife still uses it in preference to the Pronto.
ps Sorry about the scary picture
Gerbil is offline   Reply With Quote
Old 04-07-2002, 5:08 PM   #3 (permalink)
Cmon guys some of you 9617 owners must have some info.
Old 04-07-2002, 5:31 PM   #4 (permalink)
Squirrel God
Posts: n/a
I don't know if this will work on your 9617, but on the 6515 that I used to own, I was able to hold down the info key on the remote for about 5 seconds. After that, when you change the volume, it should show you the indicator on screen (or it might come up automatically before then).
Old 05-07-2002, 7:58 AM   #5 (permalink)
rct
rct's Avatar
Sorry for the delay Arch... If you go into interactive on Sky and Select Customer Services you will be able to find a list of Philips codes... I seem to remember having to try four or five before it worked. on my 9617. Write down all the codes and try them one by one. Good luck.
"In three words I can sum up everything I've learned about life: It goes on." Robert Frost.
Volunteer your PC and fight cancer! http://www.grid.org/projects/cancer/
rct is offline   Reply With Quote
Old 08-07-2002, 7:41 PM   #6 (permalink)
abl
Posts: n/a
I got my sky remote to work my 9617 first time.
I used a code off the web, think it came from: http://www.satcure.com/tech/digicode.htm
HTH Arthur
Old 08-07-2002, 8:59 PM   #7 (permalink)
rct: thanks for the help, went to sky page you suggested andtried all the codes without any joy.
abl: Thanks also will try these codes tomorrow.
Really appreciate the help, anyone know if there is a display showing volume level when you increase/decrease volume.
Old 08-07-2002, 9:24 PM   #8 (permalink)
Squirrel God
Posts: n/a
Didn't holding down the info button for 5 seconds work then?
Old 08-07-2002, 9:36 PM   #9 (permalink)
Squirrel god
sorry, yes i did try it, I assume you meen the button with the i+ symbol that gives you the various info at the top of the screen for a few seconds, if it is this one, then no it had no effect. Ment to ask you about this but forgot.
Old 08-07-2002, 9:46 PM   #10 (permalink)
Squirrel God
Posts: n/a
Yes, that's the one. Oh well... worked on the 6515... weird
Old 09-07-2002, 12:13 AM   #11 (permalink)
abl
Posts: n/a
Has anyone got the Philips remote to control a sky digibox, or anything else for that matter.
I like the remote but I haven't been able to get it to work my sony VCR or pioneer DVD...
Old 09-07-2002, 7:46 AM   #12 (permalink)
puc
Thanks: Gave 8, Got 4
The remote for my 28pw6006 will not operate my Sony vcr either but my sky remote DOES operate the TV. Weird
puc is offline   Reply With Quote
28pw9617, philips
