Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Fujitsu P42HTA51ES Brightness fluctuations and service menu options ma-ku Plasma Televisions 40 26-02-2009 1:22 PM
Samsung LE32R51B service menu problems mochu LCD Televisions 2 01-11-2005 8:29 AM
Service menu problems 40 WH 08 bug CRT Televisions 14 06-03-2005 3:36 PM
JVC 28X4 Service menu problems JT28 CRT Televisions 0 21-01-2005 5:35 PM
Panasonic Service Menu access problems chopper dave CRT Televisions 5 11-01-2004 7:59 PM
Old 11-09-2006, 4:53 PM   #1 (permalink)
TX36PD30 service menu, brightness problems
How can I get into the service menu to alter some settings? Watching Sky +, some channels are quite dark and the brightness setting on the telly is nearly 100%, surely too high? Seems ok on terestrial channels tho. Or is it my Sky + box thats at fault?
Whats a DVE disk?
Stevie
steviewilson is offline   Reply With Quote
Old 11-09-2006, 6:23 PM   #2 (permalink)
per-Sony-fied's Avatar
Thanks: Gave 47, Got 106
Re: TX36PD30 service menu, brightness problems
Always a bit of a problem with the Panny. It does not bode to well via RGB scart. Dark scenes losing a lot of detail and one tries to compensate via brightness but alas not the answer. Gamma correction is needed but NOT available through the menu or User (you and I) service menu. The only help comes from an adjustment called - Sub bright - in the service menu.
To enter
Bass up
Treble down
Hold down the "V-" key uder the TV front flap while pressing - Index - on the remote. Flicking through the settings and adjustments are achieved with the use of the scart selection buttons. Use - store - on the remote (under flap) to save settings. Write all settings down before attempting to change ANYTHING
To Exit
Press - N - on remote (under flap)
per-Sony-fied is offline   Reply With Quote
Old 12-09-2006, 6:14 PM   #3 (permalink)
stevefish69's Avatar
Thanks: Gave 643, Got 260
Whats a DVE disk?
Stevie
Try connecting the Sky + box to the PD30 using a S-VHS lead with scart on the end. The picture on my Panny improved ten fold, and the only downside is that you have to switch to sky manually.
DVE is Digital video essentials calibration DVD which helps set up all the levels correctly. Not to sure how it would help you with the Sky problem though.
Toshiba HD-XE1, Playstation 3 (60GB) , Marantz CD52MkII, Sky HD, PS Audio UPC-200HB
Audiolab 8000AP, Cinepro 3k6, Kef Reference 3.2, XQ2C (Bridged) , TDM-34DS, SVS PC13-Ultra & AS-EQ1
Panasonic TH50PZ80 & PT-AE3000E, 92" Harkness Hall Tab-Tensioned screen
stevefish69 is offline   Reply With Quote
brightness, menu, problems, service, tx36pd30
