Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Toshiba 36ZP48 and Xbox 360 'works' in 480p/1080i?! kryten CRT Televisions 5 08-01-2007 9:06 PM
tosh 36zp48 display problem colin207 CRT Televisions 8 10-01-2006 12:47 PM
Tosh 36ZP48, pink screen with component video DVD tosh SD-340E colin207 CRT Televisions 1 21-12-2005 1:07 PM
Toshiba 36ZP48 and Xbox 360 HD compatability geekingdave CRT Televisions 3 20-11-2005 2:02 PM
Xbox 360/Tosh 32wl48 Resolution bodyfodder Xbox 360 4 24-10-2005 1:40 PM
Old 09-09-2006, 6:10 PM   #1 (permalink)
Thanks: Gave 1, Got 2
Tosh 36ZP48 Display Resolution on XBox 360?
Was thinking about purchasing an Xbox 360, what's the maximum resolution will my Toshiba 36ZP48 display at please?
L00py^ is offline   Reply With Quote
Old 09-09-2006, 10:21 PM   #2 (permalink)
Thanks: Gave 40, Got 35
Re: Tosh 36ZP48 Display Resolution on XBox 360?
480p / 576p
Eiji is offline   Reply With Quote
Old 09-09-2006, 11:39 PM   #3 (permalink)
Thanks: Gave 3, Got 19
hi
my toshiba 32zp48 arrives next week
i know that if you connect a 360 to it using the component cable and switch it to hdtv you can select 480p but how can you select 576p i didnt know you could do that because the only resolutions i see on the 360 settings menu are 480p/720p and 1080i.
jpb82 is offline   Reply With Quote
Old 10-09-2006, 1:19 PM   #4 (permalink)
Thanks: Gave 23, Got 17
The 360 looks good on the Tosh at 480p - about as detailed as on my PX60 plasma at 1080i infact.
warbie is offline   Reply With Quote
Old 10-09-2006, 1:49 PM   #5 (permalink)
Thanks what i and p mean plz.
I use 1024 x 768 pixels on my monitor, although have used 640 x 320 on my other computer, how it compare with them plz?
Old 27-10-2006, 8:00 PM   #6 (permalink)
gunsnroses76
Posts: n/a
can you toshiba 32zp48p owners help me i just brought a xbox 360 premium using the included component cable on my toshiba 32zp48 i can get the high def pic but there is no sound, i know the red,green and blue phonos on the lead all go in the component on the back of tv but ive tried plugging in the other remaing 3 phonos in the other socets on the back and on the front but im unable to get sound, well i can but if i plug the red and white on the front of the tv you get sound but only if you cycle threw the avs but then doing that im left with no picture how do i get the picture and sound on the same av?
360, 36zp48, display, resolution, tosh, xbox
