Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
sick of sammy 409, want an lcd... help benjicorb LCD Televisions 0 05-09-2006 6:47 PM
Samsung 409 VS 419 which is worse Quexex CRT Televisions 10 27-06-2006 3:28 PM
Mordaunt-Short 409 Subwoofer champ102 Subwoofers and Tactile Transducers 0 31-03-2006 10:35 PM
For Sale Brand New 50 Inch Sumsung Dlp hearts Projectors 3 28-12-2004 5:06 PM
MS309 or 409? MS-Yam Subwoofers and Tactile Transducers 3 24-11-2004 11:47 AM
Old 08-09-2006, 12:22 PM   #1 (permalink)
Thanks: Gave 2, Got 0
Got a Sumsung 409 this morning......
Finally it arrived from amazon , lovely looking thing,
first thing i noticed was the tilt , it was massive , the tilt settings start at 0 and go from -7 to +7 , had to set mine all the way to -7 to get it straight,
Then the Geo , oh no , there it was , the bendy lines.......
then i tried Hi def through the xbox 360 , read a earlier post where someone was saying it was rubbish, well it didn't look too great to be honest, but then i remembered the switch on the hidef xbox cable where you could switch between hi def and tv, der i had it on normal tv , there is hope.... come on the hi def, i flicked the switch and bang , picture was amazing , stunning , , much better than i could have hoped for.
then the buzzing , it comes and goes, sometimes hardly there , so hopefully it will settle down.
then theres a strange pull plastic thing sticking out the back , looks like the sort of thing that needs pulling out , best i can describe is the plastic they put in between batteries and their connectors in kids toys, once you remove it , the toy will work...
overall its great apart from the geo , but am going to keep it , great picture otherwise, but the geo is bad, so i called up samsung and they are sending someone round next week to sort it ( i hope)
take a look at the geo , its not me , its needs sorting doesn't it ?
dancewav is offline   Reply With Quote
Old 08-09-2006, 12:54 PM   #2 (permalink)
mjcairney's Avatar
Thanks: Gave 115, Got 344
Re: Got a Sumsung 409 this morning......
It sure does.
At the moment, I would best describe it as c**p.
Cheers,
Martin.
Lounge: Pioneer PDP435FDE Plasma|LG BD390 Blu-ray|Pioneer DVR545HXS DVD/HDD|Pioneer DV575A (for SACD and DVD-A)|Pioneer VSXLX60|Sky HD|Denon TU1800DAB Tuner|Kef KHT2005.2 Speakers in 6.1 Configuration|Harmony 885|Bedroom: 26LG4000 TV/DVD Combi|Toshiba EP30|PS3 Slim|Harmony 655
mjcairney is offline   Reply With Quote
Old 08-09-2006, 12:57 PM   #3 (permalink)
Thanks: Gave 12, Got 52
I ordered mine from amazon yesterday, I was hoping they would be from the newer batch talked about that had less of a geometry problem.
Verticals look straight to me, but yes the horizontal does seem off.
Keep us posted on the outcome of the Samsung Engineer.
How long did it take for you to get the TV? Amazon have quoted 18-25th to me. Did it come any sooner than they said?
steggy is offline   Reply With Quote
Old 08-09-2006, 1:07 PM   #4 (permalink)
took about 3 weeks from amazon
Old 08-09-2006, 9:35 PM   #5 (permalink)
oh no , the buzzing is getting really loud, its doing me in ,
do all 409's buzz ?
has anyone else who has had this buzzing had it go away ?
will the engineer pretend his deaf.....
is there hope anyone ????
Old 09-09-2006, 10:41 AM   #6 (permalink)
per-Sony-fied's Avatar
Thanks: Gave 47, Got 106
Straight down in ratings I go I don't like to sound nasty but anyone who buys one of these after reading all the problems associated with it is taking a big gamble. If you can put up with it's geometry faults (I'm sure this vary's from set to set) then it does do a very good job for the money. It should be no surprise that it arrives like this... more of a surprise if you get a perfect one..... if that's possible.
per-Sony-fied is offline   Reply With Quote
Old 09-09-2006, 11:32 AM   #7 (permalink)
if it is indeed..........
i dont really have a problem with the Geo , i am sure that can be altered in the engineers menu, its the damn buzzing, things like that send me mad, i end up not listening to the tv prog , but trying to listen out for the buzzing to see if its there ,
still i'll talk to the engineer to see what he says, the picture is so good though i want it to work for the money you see, if no buzzing it would be the nuts (geo permitting of course) if not it goes back and i'll try another one, then i will have to upgrage to a toshiba lcd i suppose.
Old 11-09-2006, 4:09 PM   #8 (permalink)
Thanks: Gave 6, Got 6
Came so so close to buying one of these but it was just too big for the space available. In retrospect I'm glad I stayed away cos off all the crap reports that's been written about them on this site. 99% negative 1% positive. Says it all!!
Gammy
Gammy leg is offline   Reply With Quote
Old 12-09-2006, 12:02 AM   #9 (permalink)
Thanks: Gave 70, Got 122
Gammy
- Which is all well and good except that isn't the case at all.
There are more than a few of us around here very happy with our '409/'419.
gixxerman is offline   Reply With Quote
Old 13-09-2006, 6:01 PM   #10 (permalink)
Re: Got a Sumsung 409 this morning..The Samsung man Cometh
The Engineer Cometh.
ok he sorted out the vertical lines on the set , said he couldnt do anything about the bow, it was to do with the tube, they are all like it. not true i said , seen pictures on here........
any way onto my major gripe the buzzing !!
'The buzzing' he said that samsung has given them something to get rid of the noise but he didnt have any on him and would need to come back ,
basically i said forget it , i'll get a replacement as i only have a week left with amazon to do so and he said good idea.
so thats what i'll do , just been into the service menu myself and i couldnt seem to get rid of the bow either, still the geo's ok as the picture is superb, and as long as the buzzing can be cleared up this model will do me for a few years at the price.
i just hate the buzzing , its like an old VHS on pause. remember that
409, morning, sumsung
