| Bush 28" Giving Up The Ghost
Hi all, I've been visiting these forums as a guest from time to time to soak up some wisdom, but now I've got something a bit more specific I could really do with some help on;
I've got a 28" Bush CRT (the 4:3 one most people got from Tescos for £200) which is a couple of years old. It's been fine up until my landlord started some building work and I think some brick dust may have gotten in under the dust cover (it wasn't a very good one, the top of the set is filthy).
The problem is that it will turn on OK, then within a couple of seconds of displaying a picture, it will fade to a black screen over about 5 or 6 seconds. It will remain like this a for a good 10 minutes, then quickly fade back up to a normal picture for a few seconds, then back to the black.
I was getting this to a lesser extent about a week ago (it would be fine for 30 mins or so and the blackness would only last for a minute or two) but it's got so bad it's physically unwatchable now.
My main questions are as follows:
Is there anything anyone can reccomend I do without the help of a engineer?
If not, what's the best/chapest course of action as to getting it fixed?
Any help would be gleefully recieved.
Blue
