Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Philips DVD634 + 9607 TV Jezs DVD Players 0 30-04-2003 5:43 PM
Philips geometry problem BigB@dJ@y CRT Televisions 4 12-02-2003 4:35 AM
Philips 9607 AAG CRT Televisions 0 13-01-2003 2:51 PM
Philips 9607 jools60 CRT Televisions 2 12-08-2002 11:36 AM
Philips 36/9607..Help with how to cable up please Mike,Charlton CRT Televisions 5 20-05-2002 3:00 PM
Old 07-09-2006, 2:39 PM   #1 (permalink)
MikeRow
Posts: n/a
Red face Philips 9607 geometry problem
Hi folks, newbie here.
I have just bought a used Philips 36PW9607 and it looks good, apart from a terrible geometry problem.
Some of the time the picture looks ok, and all lines are straight. However, at other times, with certain broadcasts the picture distorts in the same way old CRT computer monitors do. The set displays terrible pincushion, pin-balance, trapeziod and parallelogram effects. These change dramatically and dynamically with different source material but mostly seem to be affected by bright backgrounds or text. It doesn't matter which aspect mode the screen is set to, except that it is more obvious where there is a gap around the displayed area, ie: 4:3, 14:9, etc. Viewing via standard RF signal or Sky digital also makes no difference, other than when displaying the Sky program "info" which just exaggerates the problem.
Is this fixable, or have I bought a dud?
Thanks for any advice.
Mike.
Old 08-09-2006, 11:49 AM   #2 (permalink)
Thanks: Gave 15, Got 36
Re: Philips 9607 geometry problem
It sounds like EHT ballooning. Obviously it depends on how severe it is, but Philips tended to use cheapish EHT stages and got quite a lot - My Philips 29" certainly does more than I'd like.
The bright content pulls the EHT voltage down, and thus the electrons move slower, so the picture gets larger in the bright area.
Not much you can do. I suppose you can swap the flyback transformer, but getting one at a sensible price might not be easy.
hamster is offline   Reply With Quote
Old 09-09-2006, 2:36 PM   #3 (permalink)
MikeRow
Posts: n/a
Originally Posted by hamster
...so the picture gets larger in the bright area.
That's exactly what happens and it is most severe once the set has fully warmed up, it seems to be less severe when it is cold. Looks like I'll have to sell it then, a pity as the picture is very good in all other respects.
However, I have just found a Tosh 36ZP46 so all is not lost, yet.
Mike.
9607, geometry, philips, problem
