Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
had 2 red segments, now all green what should i do? chillo Xbox 360 7 01-05-2006 6:35 AM
Red, Amber, Green Mole69 CRT Televisions 2 18-11-2004 9:05 AM
3d glasses (red/blue) ted26 Movies and The Cinema 23 13-02-2004 6:09 PM
green and blue stains mattheu CRT Televisions 1 25-07-2003 10:06 AM
Red/Green/Blue Line at top of screen. Audi_S2 CRT Televisions 0 15-01-2003 11:48 PM
Old 06-09-2006, 3:00 PM   #1 (permalink)
Les E's Avatar
Thanks: Gave 13, Got 16
Red, Green, Blue!!
I think I already know the answer to this, but I would like some confirmation.
I have a 32" Philips Pixel Plus CRT Television which I have had for a few years now.
But suddenly the stunning picture has decided to flicker and turn either Red, Green or Blue.
Switching off the TV for 5-10 minutes seems to rectify the problem for a while but after a few hours viewing it starts again.
Can anyone give me a heads up of what this could be...and is it time to invest in a new Plasma?
Hardware: Yamaha RX-V2600 7.1; Infocus IN76; 92" Beamax A-Series; Sony BDP-S550; Thomson Sky HD; PS2; Paradigm 150; KEF iQ5; KEF iQ2c; REL Quake and Harmony 895. Home Cinema Build HERE
Les E is offline   Reply With Quote
Old 06-09-2006, 3:44 PM   #2 (permalink)
Thanks: Gave 1, Got 41
Lightbulb Re: Red, Green, Blue!!
Hmmm... If it happens after a period of use, it may just be some dodgy solder or similar which breaks a connection when hot. Have you tried another Scart socket? (if it has more than one). If that fails, get a repair quote - if it's a minor issue it may be worth a shot (as it sounds as if the tube's OK). Any proper TV engineers out there can stop laughing NOW - just a layman's opinion!
ProfessorYaffle is offline   Reply With Quote
Old 06-09-2006, 4:03 PM   #3 (permalink)
.hack's Avatar
Thanks: Gave 56, Got 99
My old Sony KV28HX15U had the same problem, the only difference being that the picture only ever turned blue. It only happened when using the RGB scart socket, never on the composite scart.
Let me know if you find out the cause, I'd like to know in case my new KV28HX15U starts doing it again... The useless engineers I sent my old set to spent 2 weeks looking at it and couldn't find anything wrong with it!
.hack is offline   Reply With Quote
Old 06-09-2006, 4:14 PM   #4 (permalink)
Les E's Avatar
Hmm interesting. Neither the Sky Digi box or the Pioneer HDD/recorder are fixed via an RGB scart, only composite. But it may be worth changing the scarts to see if the problems persist.
I'll let you know!!
Old 08-09-2006, 9:26 AM   #5 (permalink)
Super Moderator
alexs2's Avatar
Thanks: Gave 199, Got 665
May also be the tube signalling it's about to throw in the towel.
My old Toshiba 28" did this a couple of yrs ago and required a new tube to fix the problem.
UVEM HCPC/TEAC VRDS/AV32R-DP/LP12 Lyra Argo/Krell KMA/B&W 805/PC-Ultra/300Bs and ESLs
**Please note that any views expressed are my own personal opinions and not those of the forum as a whole,or any company**
Trading rules http://www.avforums.com/forums/view....=trading_rules
alexs2 is offline   Reply With Quote
blue, green, red
