Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 10-06-2002, 3:09 PM   #1 (permalink)
orange
Posts: n/a
32ZP18Q & Tivo
Having just purchased a Tivo I have encountered a well known problem on Philips TV's with my Toshiba 32ZP18Q.
It freezes the set so the remote and the buttons on the front of the set do not work, although the picture still plays. Tivo are sending an update to my machine to cure this.
Has anyone else had this on the their set and had it cured?
Does the P version have this issue, I know it is to do with the teletext and the Q verion has a new teletext chip.
Old 10-06-2002, 10:10 PM   #2 (permalink)
Thanks: Gave 9, Got 65
You could try changing the remote address of your Tivo.
The default is '0' , but it can be set at 1 - 9.
1. Go to 'system information screen' on your Tivo, scroll down untill you see where it says 'remote address - 0'
2. Cover the infared on the remote control with your hand. Hold down the 'Tivo' button & 'pause' button at the same time untill the red led on remote flashes.
3. Press 1 (you could choose to use any number between 1 and 9).
4. Take your hand away from the front of remote and press 'right cursor' button.
5. You will see that the remote address has changed from '0' to your new number.
The Tivo remote will operate as normal now, except it is using slightly different infared frequencys.
If you still have a problem with it effecting you Toshiba, then try 2, 3, 4, etc in turn to find which works without interference.
Hope this helps.
simon1 is offline   Reply With Quote
Old 11-06-2002, 11:52 AM   #3 (permalink)
orange
Posts: n/a
Cheers Simon for your thoughts.
I was sent the 2.5.5a update of the Tivo software lastnight, which disables the Teletext subtitling feature and this has cured the problem, set now works fine.
Old 11-06-2002, 10:23 PM   #4 (permalink)
Orange, when you said 2.55a, did you have 2.55 previouly with problems?
Is 2.55a a special update then for people having this sort of problem? I'd never heard of 2.55a
Old 12-06-2002, 8:58 AM   #5 (permalink)
orange
Posts: n/a
Simon1, yes you are correct I had 2.55 and now have the 2.55a which is a special version without the facility to use subtitles on any Tivo program, recroded or live TV.
Old 12-06-2002, 9:58 PM   #6 (permalink)
Orange.
That's interesting, thanks for letting me know.
32zp18q, tivo
