Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Old 19-08-2006, 10:32 PM   #1 (permalink)
fryman
Posts: n/a
sony kv-28ws2u on the way out?
My old, but trusty Sony is playing up. Before I put it into my local repair shop to see what the damage to my wallet will be, does anyone know what my problem is:
When I switch on I get sound immediately, but no picture, just a black screen.
I can change channel, but still no picture. After a minute or two ( seems like an hour ) the picture appears, but will go off again just as quick as it came on. This happens a couple more times before everything settles down and then the tv works perfectly well.
If I were to switch off and try say, half an hour later- same thing.
Hope someone can tell me how sick my tv is.
Cheers,
John
Old 19-08-2006, 10:59 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 859
It sounds like it could be a "Lazy" crt...in which case it's terminal I'm afraid...on the other hand it could be a faulty component in the crt drive circuitry.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 26-08-2006, 8:15 PM   #3 (permalink)
fryman
Posts: n/a
Re: sony kv-28ws2u on the way out?
Had my local guy out- i was at work, but told the wife it was fixed, but repair might only last for a week, month or who knows. Basically, it is pretty much terminal, set is just old and needs replacing.
£20 spent, but at least tv turns on straight away for the time being. Guess I'll just have to do some homework befrore entering the HD revolution....
Thanks for looking,
John
kv28ws2u, sony
