Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 11-07-2006, 5:31 PM   #1 (permalink)
Thanks: Gave 1, Got 0
Toshiba 36ZP Picture Problem
I have an intermittant problem with the picture (the TV is still in warrenty but this only happens on occassion). Anyway the problem is that the picture moves down the screen in a sort of trapezium shape for a second or two then returns to normal. This can happens a few times every evening...then it doesn't happen for ages.
It happens when watching TV/DVD/XBOX/XBOX360 so I don't think it is connection related.
Just hoping someone has an idea of what the problem might be. It is under warrenty but I know that if I try to get it repaired they will say it is fine or the problem won't happen.
Hope someone can help out!
Thanks all.
cluster is offline   Reply With Quote
Old 11-07-2006, 6:26 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 857
36ZP??...Always give the full model no as there are two different chassis used.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 11-07-2006, 9:54 PM   #3 (permalink)
I think it is the 36zp46 model...non- dolby one....if that helps at all. PS not always trapeziod shape but just half th picture disappears at the top of the screen as well.
Old 12-07-2006, 3:52 PM   #4 (permalink)
Bump!!
Old 12-07-2006, 3:57 PM   #5 (permalink)
Conspicuous Member
JayCee's Avatar
It isnt a known/common fault on this model...best idea is to have a digital camera to hand and take a pic when the fault appears and show it to the engineer as proof.
JayCee
Old 14-07-2006, 4:13 PM   #6 (permalink)
Good idea, thanks for that. I'll get the camera primed!!
36zp, picture, problem, toshiba
