Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 10-07-2006, 6:28 PM   #1 (permalink)
Thanks: Gave 0, Got 7
TV connections
Hi, im pretty new to all this stuff and im on the look out for a new tv at the moment.
I just wanted to know whats the best connection out of S-video and RGB scart.
I noticed at the back of my DVD player it has both connections and i was wondering what one gives the best picture. Its just because most of the Tv's ive been lookin at have S-video as well and i just wanted to know what u guys think is best.
Also, can u use S-video for the Xbox 360 instead of RGB scart if it is a better picture ?
davie563 is offline   Reply With Quote
Old 10-07-2006, 8:36 PM   #2 (permalink)
RGB is the better of the two, although under most conditions you probably cannot tell the difference.
Nigel
nig28 is offline   Reply With Quote
Old 11-07-2006, 2:22 PM   #3 (permalink)
Hi, i just went down my local clearence warehouse looking for a nice new TV.
I saw i few i liked but the TV sets didnt say they were HD ready. but they did say the screen rez was 1280*768, this is 720p quality isnt it...?
After looking at the back of the TV i noticed it didnt have Componemt connections but the TV did have PC monitor connections. 2 of them, the old one and the new DVI input..
Does this mean id be able to run an Xbox 360 with the VGA cable at 1280*768 ?
I take it the TV cant call itself HD ready because it dosent have component or HDMI, but will VGA/DVI work for my 360 and look good ?
Im not sure about the model number, but it was a 32'' Thomson tv.
connections
