Hi beees,
A few people have posted this in the past. Last year someone had the Wharfedale M2126, which they had bought from Argos. They rang the Argos helpline (an 08.......... number given in the book) and they were told what to do.
Someone gave this solution, hope it works for you:
Press the pp button on the remote control three times. Press OK and it should be OK. Then go into setup/function/lock and disable lock.
This was posted by a member, Pete, whose User Name was, S4awx
Good luck, let us know if it works.
