Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 06-07-2006, 7:29 PM   #1 (permalink)
JVC AV-32x37HKE cut out problem
I just got given a JVC AV-32x37HKE interiArt 100Hz DigiPure Pro £d cinema sound, sounds good but it will only stay on for a couple of mins. before it switches off the screen goes red and after it switches off the stand-by light flashes. If anyone knows of this problem or what it could be and how i could find the fault. I would hate to have to shot it out as iam good and soliving problems but the problem here is finding the problem. Can anyone help in any way
john57 is offline   Reply With Quote
Old 23-06-2007, 12:51 PM   #2 (permalink)
Re: JVC AV-32x37HKE cut out problem
Did you ever get a response to your post as I have the same problem?
svcb2005 is offline   Reply With Quote
Old 23-06-2007, 6:33 PM   #3 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 855
If he had got a response it would be above your post in this thread.
I will give you the same advice as I would have given john57...get it looked at by an experienced TV engineer...modern TVs are not d-i-y fixable.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
av32x37hke, cut, jvc, problem
