orange
I am based in Wiltshire. I may try and see some of the sets in the surrounding stores at the weekend although it is unlikely that I will be able to hear it in a store.
Last night I watched some DVDs (Shrek, The Matrix, Ultimate Platinum) for the first time (my new 510 arrived!). Even using the bundled component cable and a crappy phono for the digital audio, the picture and sound was pretty amazing. The dirty screen appears less obvious through the DVD than the tuner/VCR which is good news.
Anyway back to the buzzing/humming. I thought the extra humming I get on bright scenes was purely through the speakers. I'm not so sure now - even if I mute the sound, brighter scenes cause an audible increase in the humming (which is even worse when you turn the sound back on). I'm not sure this is right is it? This increases even more in PM-1 and PM-2 where the brightness is higher (my PM-M is from PM-3 with settings 45, 55, 50, 00, -50, 100Hz, Auto).
If I run the CLAMP test on my Ultimate DVD Platinum where there is a black box on a background that cycles from white to black (no sound from DVD but not muted either), the humming increases as the background gets near white. Again PM-1/2 are worse and muting the sound only slightly lessens this effect.
Additionally, I get the audible buzz on 14:9 zoom mode as well as Cinema and Subtitle (14:9 seems to be overscanning vertically as do Cinema/Subtitle, whereas the other modes don't - could this be why the buzz occurs?).
2 main things for me now are (may go for a swap based on these):
1) buzzing/humming
2) dirty screen
If 2) gets better with use then I'll be happy (I'll check sets in stores again to see if they have the same problem - they have been on a long time so should indicate if it does get better).
PS: Saw the brighter sides last night - not really a problem for me yet as it is only obvious when screen is totally black (also noticed brighter side on right appears bigger than that on left).
