Originally Posted by ljh10 yes did mean is'nt going to cost a bomb
just a bit concerned as the engineer who came round the other day just kept rattling on about the it was the tube that had gone
Thanks |
Based on what you have said and I presume you have read the various threads, it does not sound like the tube has gone. Get a second opinion.
Toshiba customer services are superb and will send the replacement part to an engineer of your choosing free of charge - I expect that labour should be around £50-£60 as the actual time involved to fix it is minimal at around 30-45 mins.
Good luck. Any more specific info should be directed to Jay Cee (see above post) as he is THE MAN for this type of query! He helped me enormously.
