Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 10-05-2006, 4:11 PM   #1 (permalink)
pixel burnout problem on my Toshiba?
I have a 27" Toshiba flat screen that is 2-3 years old. The last few weeks, I've had horizontal lines across the top of the screen, like 4-5 alternating lines of pixels are burnt out. Its there with any type of connection I make, and it doesn't matter if its my cable or or a dvd. sometimes its worse, sometimes it disappears, sometimes the left side is multi-colored.
anybody have any advice, or is it time for a new TV?
hockeytown9321 is offline   Reply With Quote
Old 10-05-2006, 4:18 PM   #2 (permalink)
ijd
Thanks: Gave 105, Got 154
can you post a picture?
ijd is offline   Reply With Quote
Old 10-05-2006, 4:21 PM   #3 (permalink)
actually, no. i don't have a digital camera or scanner.
Old 10-05-2006, 5:59 PM   #4 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 855
Is it a CRT or LCD?
If CRT report back with the model no.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 10-05-2006, 6:15 PM   #5 (permalink)
Originally Posted by JayCee
Is it a CRT or LCD?
its a crt, Toshiba model #27AF45
Old 10-05-2006, 6:18 PM   #6 (permalink)
Conspicuous Member
JayCee's Avatar
I take it you're not in UK/Europe?
JayCee
Old 10-05-2006, 6:19 PM   #7 (permalink)
no sir, US of A.
Old 10-05-2006, 6:24 PM   #8 (permalink)
Conspicuous Member
JayCee's Avatar
no sir, US of A.
I thought so.
That model is not released/different to UK/Europe models.
You would be better off posting this at a USA-based forum www.avsforum.com
Good luck.
JayCee
Old 10-05-2006, 6:28 PM   #9 (permalink)
I thought so.
Good luck.
thanks, i just googled for TV troubleshooting and this is the first site I found.
Old 10-05-2006, 6:36 PM   #10 (permalink)
Conspicuous Member
JayCee's Avatar
When you do repost in that forum don't report it as "pixels burnt out" as CRT TVs don't have pixels...only LCD and Plasma.
Your symptoms should be reported as "Retrace lines" if they are white in colour or "Frame Lines" if black.
JayCee
burnout, pixel, problem, toshiba
