Originally Posted by satmanbasil
Hi m8s
I have a Sanyo CE32WP%-B (phillips tube i think)
Anyway i need the engineer remote code to get into the service menu to make adjustments to the colour balance
Is the greyscale off? i.e. do you have a predominance of one colour?...if so the crt is highly likely to be at fault and no amount of adjustment to the guns will make any difference.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
