I have a new PB50 fault to throw in as well as the noisey PSU.
Every now and again the remote will cease to work as well as the front panel functions. I have also tried to use other multi-user remotes and they don't work either.
Anyone else had this problem?
Had the same problem when using other remote for my video.
After using the video remote for a while, the tv remote just died.
Had to turn off and switch on again to work.
Strangly enough this is the exact same problem with my Panny. After using the remote for my video for awhile (the usual fast forward through adverts) all TV functions would cease with both remote and front panel.
My video is a JVC. Is this the make of your VCR?
Anyway the repair man is coming round to grunt at the TV soon so I probably will have more to add later.
