Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Old 02-04-2002, 10:51 AM   #1 (permalink)
rjs1974
Posts: n/a
Rear Projection TVs
Are these better or worse than CRT TVs??
Assuming I had digital TV as opposed to analogue, would it compare favourably with CRT?
How does DVD playback compare too?
They seem much cheaper per inch than CRT TVs. Why??
Thoughts please?
Old 02-04-2002, 11:26 AM   #2 (permalink)
Thanks: Gave 95, Got 75
YES they are better IMO and i've had a few TVs in my time.
'Digital' meaning IDTV? then there shoul dbe no difference, not sure what you mean here.
DVD looks SUPERB, but you MUST use RGB SCART or component if your DVd and TV support it.
Don't know why they are cheaper, probably because there no glass tube for a start.
Kevo is offline   Reply With Quote
Old 02-04-2002, 11:31 AM   #3 (permalink)
rjs1974
Posts: n/a
Kevo....
I meant Sky Digital for example, rather than analogue TV.
Is anologue picture quality good too?
Do RP TVs suffer from dodgy geometry in your experience?
You would rate them higher than CRT TVs? Why?
Cheers mate!
Old 02-04-2002, 11:52 AM   #4 (permalink)
Both Digital & Analogue TV look fine.
The quality of Digital can vary somewhat and sometimes look worse than analog (especially football). Obviously with a larger TV any flaws will show up bigger!.
Analog quality depends on the reception you get, mine looks OK.
I have never had to adjust the Geometry on my TV, but I can't speak for other makes.
I rate them higher becsue I like the 'cinematic' feel it gives to the picture. The 100Hz processing is the best I have ever seen on ANY TV. The screen is a matt finish, no reflections and the picture is CRYSTAL CLEAR.
I have had it since December last year and it still never ceases to amaze me.
I watched Flah Gordon DVD yesterday and I was just in awe with what I was seeing. Not the film itself, it's corny as hell, but the colours and clarirty of it have surpassed anything I have yet seen on DVD. It is now my new 'demo disc' to show off the pic quality of the TV.
Basically there are probably only two manufactures to chose from with RPs....Toshiba & Pansonic. Toshiba edges it with the picture quality. Make sure you get a 100Hz model as this makes a BIG difference.
projection, rear, tvs
