Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 13-03-2006, 11:03 AM   #1 (permalink)
CRT TV for Xbox 360 - 760p
Hello all,
Need your advice...
Any good CRT HDTV model to recommend for Xbox 360 which support up to 1080i ??
THanks...
kaneshiro21 is offline   Reply With Quote
Old 13-03-2006, 4:24 PM   #2 (permalink)
Thanks: Gave 2, Got 2
There are currently no HDTV capable CRT TVs in Europe at all. There are plenty in the US though. Apparently Samsung announced "short-neck" CRT HDTVs for 05/2006 in Europe. No exact specs yet, but these should have all the advantages of current LCD HDTVs, but lots cheaper (prices should be around 350 pounds for 30"), and without the response time issues LCDs have
Looking forward to this one!
Yamaha RVX 650 [to be replaced] - Front:Wharfedale Diamond 8.3 - Centre: Wharfedale Diamond 8.C - Surround: Eltax Liberty 5+ - Sub: BK XLS200 - Sony CDP270 (oh yeah!) - Sony MDS JE480 - Samsung DVD HD870 [to be replaced] - PS3 [JP@320gb] - 360 Elite + HDDVD Drive
thelordmagus is offline   Reply With Quote
Old 13-03-2006, 4:32 PM   #3 (permalink)
Thanks: Gave 3, Got 10
I have just seen this could be the answer to what you are after, will be looking into one myself!
http://www.reghardware.co.uk/2006/03..._ready_crt_tv/
Conzy is offline   Reply With Quote
Old 13-03-2006, 4:51 PM   #4 (permalink)
That's exactly what I was mentionning above
I have seen that there JVC make some HD compatible CRTs. Google JVC HV-28D40 for example.
It seems though that they lack HDMI or other digital inputs... not sure that the aforementioned samsung screens are going to have them either...
These are thrilling times for tech freaks, but it's far to confusing in any case...
Old 13-03-2006, 4:59 PM   #5 (permalink)
Thanks: Gave 15, Got 37
More news on the Samsung
http://www.t3.co.uk/news/247/enterta...t_hd_ready_crt
Ascari is offline   Reply With Quote
Old 14-03-2006, 9:33 AM   #6 (permalink)
Soundwave's Avatar
Thanks: Gave 198, Got 145
You can get the JVC HV32p37S 32" CRT which is what I've got & it's 1080i compatable via Component.
So if you buy the 360 Premium pack that comes with the HD Component capable your laughing HD gaming is at your finger tips & all for about £380 delivered from Empire Direct (Which is where my one came from)
HTH
Neil
Soundwave is offline   Reply With Quote
Old 14-03-2006, 1:29 PM   #7 (permalink)
Thanks: Gave 5, Got 9
hd ready CRT
sounds like a very exciting announcement. ID like to see:
1. HDMI imput
2. Component imput
3. 2 scarts
If the above connections are present i may consider buying this set.
However i felt the same last year when they first released 'slim fit' tvs and they turned out to be a massive disappointment - aparantly they are terrible with sky and football?
It would be great if samsung solved the inherent problems with their first attempt of 'slim fit'. If they do acheive it, i would say that there will be big sales here in Ireland and Britain.
Anyone got any more info/opinions about the new samsung slimfit crt tv?
meath man is offline   Reply With Quote
Old 14-03-2006, 4:57 PM   #8 (permalink)
Thanks: Gave 4, Got 2
If they put a digital freeview box inside I'll definitely be interested!
Sabre is offline   Reply With Quote
Old 15-03-2006, 12:22 PM   #9 (permalink)
Thanks: Gave 7, Got 8
HTH
Neil
My brother is looking for a cheap hd tv for his 360,would you recommend this tv.What does hd gaming look like on it?Any other info would be great.
mickeyb01 is offline   Reply With Quote
Old 15-03-2006, 2:07 PM   #10 (permalink)
Soundwave's Avatar
Hi mate,
Unfortunately I dont have a 360 to run on it yet, been too busy wasting the money on Retro gaming gear
However for normal SD TV, DVD & X-Box/Game Cube/PS2 through RGB I cant fault it.
PQ is excellent (Once you have a quick fiddle with the settings)
Sound is great (although mine runs through AV setup so cant comment fully)
Enough connections to keep most people happy...
3 x Scart (2 RGB)
1 x Component
1 x S-Video
1 x Composite
2 x Audio Out (1 connected to the Component)
Ok so it's not totally future proof for HD TV/DVD or Blu-Ray but as a stop gap set till LCD/Plasma HD gets better & cheaper its doing exactly what I want it to do & then some.
All of my mates & family that have seen it think it's a fantastic set & cant believe how cheap it was...IMO it embarrases any LCD or Plasma I've seen so far below the £1500 mark (I'll wait for the flaming to begin with that one )
I honestly cant recommend the set enough.
HTH
Neil
Old 15-03-2006, 2:16 PM   #11 (permalink)
Thanks: Gave 0, Got 3
it seems Philips is going to sale soon the new 28PW9551 and 32PW9551 CRTs they both support 480i/p, 576i/p, 720p@50/60 and 1080i@50/60, they have 1 HDMI connector, 1 component (HD capable) and 1 RGB SCART socket.
You can see them in www.philips.nl and/or get the PDF user manual from:
http://www.p4c.philips.com/files/2/2...12_dfu_fra.pdf
JVC HV-36P38 - Pioneer LX5090H - DVDO iScan VP50 - Panasonic RP82(SDI modded) - Sony DVP-NS730P - Oppo DV971H - Oppo 983H
JavierS is offline   Reply With Quote
Old 15-03-2006, 7:41 PM   #12 (permalink)
mug
Thanks: Gave 13, Got 8
looks like samsung has some competition
mug is offline   Reply With Quote
Old 18-03-2006, 12:03 PM   #13 (permalink)
Lobo Soulman
Posts: n/a
The problem for me with them is the weight and sheer bulk.
The one neil recomended weighs in at like 50Kg !!!!!
Maybe I move around to much but I wouldnt fancy lugging that down a few flights of stairs!!!
Now a nice HDTV LCD same size can be around 18kg. So I can move it around the room to see where it looks best. It costs about three times as much though
Fingers crossed for the samsung one, if its slimmer and lighter could def be one I might consider.
Old 18-03-2006, 4:08 PM   #14 (permalink)
Soundwave's Avatar
Erm yep they arent light by any stretch of the immagination...had to lug my one up 3 flights of stairs to get it into the flat
Luckily enough the Empire Direct delivery guys were great & did most of the work themselves
Still not as bad as the set I donated to my parents...36" Hitachi which weighed in at 75kg
Neil
Old 19-03-2006, 8:45 AM   #15 (permalink)
Lobo Soulman
Posts: n/a
That is actually heavier than me.....
360, 760p, crt, xbox
