03-03-2002, 10:01 PM
#1 (permalink)
| | Member
Thanks: Gave 0, Got 0 | How do I disable sound on a Sony TV?
Hi guys, I have a Sony 32FQ75 and I want to disable the sound from the TV. Now when I mute the tv it leaves a icon in the corner. The otherway (the way I do it now) is to turn the volume right down.
The problem I have is, my flatmates can't be bothered to swtich the amp on, or my amp is set for DVD and they don't know what is wrong and turn the volume right up, then they realise it is on DVD and change to DBS, then BOOM my speakers come close to exploding!! Very frustrating.
So I want a way so I can switch off the sound for GOOD. I use SKY passed through my DVD via scart. The only thing I can think of is to buy a video only scart cable, this should be better for my loewe dvd player anyway and will stop the sound coming from the DBS.
But if you know of another way please let me know.
03-03-2002, 10:36 PM
#2 (permalink)
| | Senior Member
Join Date: Jan 2002 Location: Kirkcaldy (but i'm not a Fifer)
Thanks: Gave 81, Got 211 |
Seems to me your problem is not to disable the sound from your tv,but to disable your flatmates from touching it in the first place.  If they cant be bothered to learn how to work it then they shouldnt be using it in the first place.I would go crazy is somebody treated my equipment like this.
03-03-2002, 10:42 PM
#3 (permalink)
| | Member
Thanks: Gave 0, Got 0 | I know it's painful
It is very annoying, especially when I ask them not to. It is not very hard and really p*sses me off.
I am thinking of buying a remote to make everything really easy for them, (and me).
We will see..
03-03-2002, 11:44 PM
#4 (permalink)
| | Member
Flatmates ?? *SHUDDER* |
03-03-2002, 11:45 PM
#5 (permalink)
| | Senior Member
Thanks: Gave 19, Got 96 |
Why don't you always return the amp back to normal viewing/listening after you have watched a DVD????
Seems the easy solution to me m8. That way, your flat mates will just have to switch everything on and they shouldn't have to fool about with anything.
04-03-2002, 12:56 PM
#6 (permalink)
| | Member
I know, but say I am not there and I am on my PC, they are watching a DVD, that is fine, but then they put the TV on then turn the volume right up, it is when I am out the room.
I guess electric shock treatment might teach em...
04-03-2002, 1:06 PM
#7 (permalink)
| | Veteran Member
Thanks: Gave 122, Got 413 |
pronto time i think.....with some clever macro's!!
oh, and yes get rid of the lazy flatmates...
__________________ Sony STRDB930, Rotel RMB-1075, Sony KDL-40X2000U, HD HTPC, B&W CDM 1NT, CNT & SNT, MF A3 24-bit DAC, SkyHD, TSU7000 ProntoPro NG, QED cables
Follow my PC Case mod project here: http://www.hardforum.com/showthread.php?t=1189553 |
04-03-2002, 1:17 PM
#8 (permalink)
| | Guest |
It seems to me that the real issue has not been addressed. The problem is that a mute icon remains on the screen. Why? This is surely bad design.
04-03-2002, 1:24 PM
#9 (permalink)
| | Prominent Member
Thanks: Gave 95, Got 75 | Re: I know it's painful Quote: Originally posted by garrad I am thinking of buying a remote to make everything really easy for them, (and me). | You want the Philips Pronto.
With this I have set up a macro that turns on the amp, turns the volume down on the TV and switches to the AV1 channel....all from one button.
I also have another macro that reverses the above.
This would be ideal for you and especially your flatmates who should all chip in for the £150 for the Pronto.
04-03-2002, 1:25 PM
#10 (permalink)
| | New Member
welcome to the world of the sony 32fq75 |
04-03-2002, 3:57 PM
#11 (permalink)
| | Super Moderator
Join Date: Jul 2000 Location: Somewhere in South Yorkshire
Thanks: Gave 464, Got 946 |
I think, if it was mine, that I'd do exactly what you have already suggested; remove or disconnect the audio signals from the SCART cable.
Of course, if it weren't for those wretched SCART things, it would be a much easier matter to just pull out the audio signal cables.
Nigel Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums. |
