Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 11-03-2006, 7:40 PM   #1 (permalink)
timtim
Posts: n/a
Pal Ntsc ...???
Hi all. I have a Panasonic tx 32pm11 widescreen tv. Whenever the camera moves, I can clearly see jagged edges round certain objects (mainly with white color). It is like there are horizontal lines across the screen. Does this have anything to do with PAL or NTSC settings? Or is this normal for a widescreen TV?
It is most obvious with playing DVD's, but when I play DIVX files (on the same player) it is hardly noticable.
THX.
Old 11-03-2006, 10:57 PM   #2 (permalink)
Thanks: Gave 24, Got 38
It is more likely to be the digital processing, which is there to "improve" the picture.
Do you have the facility to turn this off?
Tight Git is offline   Reply With Quote
Old 12-03-2006, 12:17 AM   #3 (permalink)
timtim
Posts: n/a
Hi Tight,
to make a long story short, they delivered the tv with the wrong remote, so I m not able to change the settings, except for the screen size.
I'll have a new remote in a couple of days. So if I turn off all the extra settings on the tv, it might work fine? let's hope, thx for trying to help
ntsc, pal
