Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 08-03-2006, 2:53 PM   #1 (permalink)
Markcctv
Posts: n/a
Panasonic Screen Went Green With Lines
We where all in front of the tv the other night then all of a sudden the screen went green with lines going in a zig zag across it, then it switched itself off. Can any one help.thanks
Old 08-03-2006, 3:15 PM   #2 (permalink)
Super Moderator
alexs2's Avatar
Thanks: Gave 199, Got 665
I may be wrong,but it sounds exactly the problem we had with our old Toshiba a while ago,and it signalled the end of the tube,with the same symptoms as you've quoted.
UVEM HCPC/TEAC VRDS/AV32R-DP/LP12 Lyra Argo/Krell KMA/B&W 805/PC-Ultra/300Bs and ESLs
**Please note that any views expressed are my own personal opinions and not those of the forum as a whole,or any company**
Trading rules http://www.avforums.com/forums/view....=trading_rules
alexs2 is offline   Reply With Quote
Old 08-03-2006, 3:41 PM   #3 (permalink)
Thanks: Gave 5, Got 9
yup, sadly ur tv is almost dead
i had a tosh which lasted over 10 yrs then went blue with flyback lines on the screen, soon to be told the tube was dead...
ismael-1986 is offline   Reply With Quote
Old 08-03-2006, 3:56 PM   #4 (permalink)
Thanks: Gave 14, Got 25
Markcctv,
Probably the green output driver on the c.r.t. base board has failed. This could drive the green too hard so that the set shuts down in protection mode.
Get an engineer to check it out; it may not be expensive.
zircon3035 is offline   Reply With Quote
green, lines, panasonic, screen
