01-02-2002, 3:42 PM
#1 (permalink)
Thanks: Gave 12, Got 3
So How Big Is the screen??
This is my first post - so apologies for any apparent ignorance concerning the question!
I've got a 5 year old 28" 4:3 Toshiba which has served me well, but I've been desperate to get hold of a widescreen set since I got my first DVD player 3 years ago.
Due to the size and configuration of my lounge, a 32" is about as big as I can go and my question is - actually how much bigger is the screen in terms of Inches (width x height) compared with a 28" 4:3 set.
I know it's not going to have as much height, but I really want to know what I'll be gaining in terms of width to see if it's really worth upgrading (there's actually nothing wrong with the Tosh). I want the largest viewable screen possible for watching my DVD's.
My alternative is to get the builders in, block off the double doors leading to the dining room. Then buy a new three and two seater sofa which would in turn free up the bay window to accomadate a 36" widescreen or 42" Plasma. While more preferable, my budget is unlikely to stretch something this drastic!
Can anyone help?
Cheers!
01-02-2002, 3:51 PM
#2 (permalink)
There won't be a lot in it - obviously it'll be wider but the height won't be much different - but it's worth it.
I replaced a 29" Sony 4:3 with a 32" Philips W/S and was happy with the difference but then I swapped that for a 36ZP Tosh (Picture Frame) it only takes up the same space as the 32" Philips but is a BIG dfference - if you're game for spending the cash get the 36" Tosh.
OG
01-02-2002, 3:57 PM
#3 (permalink)
hmm tricky. You are right you will lose a few inches from the height but I only have a 28" wide screen  so I don't actually know. I guess the safest thing is to pop down to your local dealer and get a little tape measure.
Or you could check out some TV manufacturers websites and see if they list the size of the things?
Just a thought
01-02-2002, 4:13 PM
#4 (permalink)
Thanks: Gave 10, Got 9
To get the width and height of a screen, find out what the viewable diagonal is. On plasma screens and projection TV's, it is the same as the screen size. On regular TV's, it is a pair of inches smaller since the size specifies the diagonal of the entire faceplate of the tube and not just the phosphor.
Using Pythagoras theorem, we find that
the width of a 4:3 screen is 80% of the diagonal, the height 60%
the width of a 16:9 screen is roughly 87% of the diagonal, the height roughly 49%
This makes a 32" widescreen smaller in height than a regular 28" screen. The 32" widescreen has a diagonal of 760mm, making it 662mm wide and 373mm high; the 28" regular screen has a diagonal of 670mm, making it 536mm wide and 402mm high. In other words, even one size bigger the widescren is about 3cm lower than the regular screen. However, you gain more than 12cm in width.
So, in order to get a similar height on a widescreen set as a regular set, you need to step up at least one screen size or even two. Remember that once you reach the plasma and projection sets, you get an additional 5cm 'for free' to the diagonal than on a tube relative to screen size, because of the different way of measure.
Thank you Wayne Coyne, for thanking Jack White for the fiber-optic Jesus
01-02-2002, 4:15 PM
#5 (permalink)
A 32" (76cm) widescreen screen is the actual screen width from side to side but the old 4:3 screens are usually measured diagonally across trhe screen. So a 32" widescreen is actually more than 3" wider than an old 29" 4:3.
I have just gone from a 25" Sony to 32" W/S and it is much better.
Can you switch your old set to W/S. If so try it and then measure the black strip top and bottom and the picture width. Then pop down Currys with your tape measure and compare.
01-02-2002, 4:21 PM
#6 (permalink)
Thanks: Gave 122, Got 414
are u sure they are measured width ways for widescreens??
Sony STRDB930, Rotel RMB-1075, Sony KDL-40X2000U, HD HTPC, B&W CDM 1NT, CNT & SNT, MF A3 24-bit DAC, SkyHD, TSU7000 ProntoPro NG, QED cables
Follow my PC Case mod project here: http://www.hardforum.com/showthread.php?t=1189553
01-02-2002, 4:40 PM
#7 (permalink)
Thanks alot for the feedback.
OG, you could have hit the nail on the head. I've just checked out the dimensions of the 36ZP cabinet and you're right - it is hardly any bigger than the 32" set cabinet (885mm x 620mm x 601mm)
I take it you haven't experienced any of the problems other forum members have with this set?
I would gladly shell out the extra cash for a 36" TV if it will fit and if it's recommended.
Thanks to Zacabeb for the maths refresher - it's been 15 years since I scraped a C in Maths. Before I posted the question, I actually tried to work it out using this method, but couldn't for the life of me remember the formula!
01-02-2002, 4:43 PM
#8 (permalink)
That's a bummer, thought i were watching a 36" screen now it's down to 30"..........been had again.........!!!
01-02-2002, 4:59 PM
#9 (permalink)
Thanks: Gave 95, Got 75
A 32" (76cm) widescreen screen is the actual screen width from side to side.
Get your measuring tape out Mitch.
I think you'll be surprised to find that the width of your TV is somewhat smaller than 32".
01-02-2002, 5:28 PM
#10 (permalink)
thought so....its always measured diagonally....
01-02-2002, 6:32 PM
#11 (permalink)
Steve
I'd recommend it 100% - I'm a fussy b45t4rd and I'm over the moon with it. I know people have had problems but many have also stressed how pleased they are with it.
Any set can have problems, the Sony I bought in '92ish had problems as did the £500 VCR I bought at the same time and the main dealer I got it from didn't want to know, no chance of a replacement or refund. I had the Philips replaced more than once etc etc.
What ever model you decide on, there's a fair chance that you may have a problem so the key is to pick what you fancy and buy it at the right place - an Internet retailer is a good start because they can't argue about giving you a refund within 7 days if you don't like it (Distance Selling Act). I got mine from www.qed-uk.com who were excellent when I was having problems with the Philips.
Good luck!!!!!!!!!
OG
04-02-2002, 9:50 PM
#12 (permalink)
OG,
Many thanks for that - I've been down to Allders to have a look at the set and I reckon it should fit OK in the space. It looks great.
It could be a winner....now I've just got to sell the benefits of a 36" TV to the missus....
Cheers!
11-02-2002, 10:48 AM
#13 (permalink)
Thanks: Gave 6, Got 0
I had the same space problem, but smaller. I could only fit in a 28 inch widescreen, or 32 if I went for the Tosh. However, I don't really want to spend that much money. Since I'm only limited widthways, I'm seriously considering getting the Thomson 33" 4:3 TV. This gives a widescreen picture that's equivalent to around a 30.5" set, but of course gives a much bigger picture on 4:3 broadcasts. They do a 37 inch model which I've read a good review of on the web, but unfortunately can't remember where. You can find the set at unbeatable.co.uk (Thomson 37MH44E). Might be worth a look, even if just out of curiosity.
11-02-2002, 12:52 PM
#14 (permalink)
Oops!. Must of had a bad hangover that day......
Anyway, Size doesn't matter, its what you watch on it that counts.
I still think a 32" widescreen is visibly much better than a 29" 4:3
11-02-2002, 1:09 PM
#15 (permalink)
The argument is that widescreen is a closer approximation of the human field of view. I agree with this argument when it comes to cinema, and you're seeing the screen in part with your peripheral vision. But the quality of TV's is not good enough to have such a wide viewing field, so a TV will only ever occupy the centre of your field of vision. Our central stereo field of view (that which we can see with both eyes) actually has the oppostie aspect ratio (tall and thin, portrait mode, etc). This is why books are generally this way up. This argument would make a 4:3 TV better, and personally I go along with this, though it doesn't look so hi-tech. The problem is, films are made for the big screen, so if you want to see it like it was made, you need widescreen. Modern 4:3 TV's should switch to 16:9 mode, so you still get 625 lines, but squashed as appropriate. You will get the black bars top and bottom, which some people find unacceptable. If you view 4:3 transmissions or videos on a widescreen, you have to put up with bars at the sides or a stretched picture, both of which I find ugly. More and more transmissions will go widescreen with time. Has a widescreen TV got extra width or less height? You'll have to make your own mind up.
