Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Galaxy Quest Blu-ray ReviewMy Bloody Valentine - Special Edition Blu-ray ReviewThe Universe: Complete Season One Blu-ray ReviewTerminator Salvation Blu-ray Review20th Century Boys: Chapter 2 - The Last Hope Blu-ray Review
North By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray Review
Panasonic SAXR45 opinions fuglyface AV Amplifiers and Receivers 3 23-06-2003 10:54 PM
Advice and opinions wanted launcher CRT Televisions 0 19-03-2003 6:35 PM
Opinions wanted: Kef Eggs and a REL Quake. DJWillis Subwoofers and Tactile Transducers 12 30-09-2002 11:00 AM
Sony VPLS900 - Reviews, Opinions wanted larry_1000000 Projectors 3 12-08-2002 8:44 AM
opinions wanted please wynouk Speakers 4 01-05-2002 12:32 PM
Old 01-02-2002, 1:40 PM   #1 (permalink)
jon smith's Avatar
Thanks: Gave 149, Got 115
Panasonic 42PT10 - opinions wanted
Hi folks
Right, just getting down to replacing my Samsung TV. Had a very nice discussion with Brian at Robert Whyte ltd and I can now choose what TV I want.
Have finally decided that I want to stick with widescreen, was tempted to return to the 4:3 clan. But 16:9 looks better in the house.
Was pretty much sold on the Toshiba, but have just come across the Panasonic model. Haven't seen any reviews though, which is a little annoying.
The Panasonic - Does it have component inputs? Or is the progressive scan done internally. I was after component for my GC (as it doesn't output RGB).
Can you watch 4:3 mode material in RGB (or does it automatically stretch to 16:9, like my Samsung did. Does it have black or grey lines at the sides for 4:3 material?
Any thoughts appreciated, especially on the Panny as there isn't much written about it.
jon smith is offline   Reply With Quote
Old 01-02-2002, 2:20 PM   #2 (permalink)
laurel's Avatar
Hi Jon
I have the Pana.
You can check out some of my comments by searching on TX42PT10.
No component inputs, three scart with 1 RGB capable.
There is the option to switch between 100hz, auto and "progressive" on the picture mode, this gives (at least to me) a slight flicker due to the 50hz refresh.
You can watch 4:3 from RGB Source. The viewing mode is quite flexible, you can switch between 4:3 (with black bars), zoom mode, Justified (which stretches at the outer edges) and Auto (which seems to stretch variably depending on the viewed material). You can switch between these at will.
I'm pretty happy with the purchase so far.
Laurel
PS. Anything else I can help with please ask.
laurel is offline   Reply With Quote
Old 01-02-2002, 2:40 PM   #3 (permalink)
Does the Panasonic still have only one central point for converging or has it copied Toshiba and Sony by introducing points around the edge of the screen too? Does it still have a reflective screen?
delta is offline   Reply With Quote
Old 01-02-2002, 2:52 PM   #4 (permalink)
laurel's Avatar
Delta
The convergence has two options in the normal "user" menu. The first allows a "general" central convergence. The second allows a 9 point convergence with points around the screen.
In addition, from the service menu, a very detailed 64 point convergence can be accessed.
The screen is not "matt" like the tosh and is "slightly" reflective when switched off. However, in operation this seems to be almost invisible. The manual states that the screen is supposed to have some kind of "anti-reflective" treatment. I have not managed to discover what this "treatment" is yet - but it seems to work!
Laurel
Old 01-02-2002, 3:36 PM   #5 (permalink)
I can't comment on the quality of the Plasma TV you are asking about but I can advise you on something else. DO NOT buy from Robert Whyte Ltd. They were very helpful when you asked about the tv ?? I bet they were, the problem is after you give them payment. Thats where the interest stops. Buy from them at your peril mate. Do a search on these forums for Robert Whyte and you'll find plenty of irate buyers.
HBK757 is offline   Reply With Quote
Old 01-02-2002, 3:46 PM   #6 (permalink)
laurel's Avatar
HBK747
This is a rear-pro set not plasma.
Your right about Robert Whyte though. There do seem to have been a few unhappy customers.
I purchased from qed-uk at £1596 delivered.
Jon - how much were you quoted?
Laurel
Old 01-02-2002, 5:23 PM   #7 (permalink)
jon smith's Avatar
Laurel - thanks for your comments, I have done a search and was interesting reading. Does the progressive scan only work with rgb input, or can you use it with S Video inputs as well. I take it as well that the only S Video (proper) input is at the front. Thanks for your help.
Robert Whyte haven't quoted yet, but i'll make sure I don't have to pay any on top of the Samsung i'm replacing. (about £1660)
HBK757 - don't worry, I know all about Robert Whyte. The main complaint thread is from me (I also mentioned them to you on the DVD forums). In a way i'm better off staying with them now, because of the previous complaints they respond more now. So whilst I wouldn't recommend them to anyone, I do at least have a relationship with them and know things will get done. You got your TV fixed yet?
Old 01-02-2002, 5:29 PM   #8 (permalink)
Unfortunately no not yet. The engineer is coming out on Monday to have a look at the TV. Let's hope he either writes the thing off or fixes it, cause I wont be waiting x number of weeks for it to be repaired ect...
Old 01-02-2002, 5:35 PM   #9 (permalink)
laurel's Avatar
Hey Jon
Works with all inputs.
By proper i assume you mean the 4 pin din connector? Then yes - this is at the front. However, 2nd and 3rd SCART at the back are also Svid capable (just use a SCART to Svid lead).
Laurel
PS Either this is a bloody good set or nobody else has one - cos there is a distinct lack of complaining on the forums.
Old 04-02-2002, 5:22 PM   #10 (permalink)
jon smith's Avatar
Well, i've gone for the Panasonic over the Tosh in the end. I had a look at them over the weekend in Selfridges and over at PRC in Ilford. All badly set up, but did the best I could.
In the end it came down to what would look best in my room. I prefer the looks of the Panny and it just feels better, so I went with my instinct. No component, but the inbuilt progressive scan should help make up for that.
Thanks for your help Laurel. How much was the service manual and where did you order it from?
Old 04-02-2002, 5:28 PM   #11 (permalink)
Anyone that has this TV have an opinion on Sky Sports broadcasts ? I've heard 100Hz makes football games look pretty bad with digital artifacts.
Thanks.
Old 04-02-2002, 6:00 PM   #12 (permalink)
laurel's Avatar
Jon
Welcome to the small but perfectly formed TX42PT10 owners club.
Still waiting for a response from the official Pana spares people (0870 241 7244). They had none in stock and no reference for the new manual. I have chased a couple of times and they are apparantly waiting for pricing/deliveries from Panasonic.
I'll let you know if I hear anything.
Do you have the set yet or are you awaiting delivery? Let me know what you think once you have the baby fixed up.
HBK757
Unfortunately I don't have Sky. What I can say though is that you can switch the 100hz on and off, so if there is a problem - it's curable!
I haven't noticed any particular issues with the 100hz implementation yet.
Laurel
Old 05-02-2002, 8:56 AM   #13 (permalink)
Posts: n/a
Cool panasonic tx42pt10
THE PANY HAS TWO RGB CAPABLE SCARTS NOT ONE
SCART 1 (AV1) RGB OR COMPOSITE
SCART 2 (AV2) SVHS OR COMPOSITE (AND Q-LINK)
SCART 3 (AV4) RGB,SVHS AND COMPOSITE.
I'M FIRMLY OF THE OPINION THAT THIS IS THE BEST VALUE
OF ANY REAR PROJECTION SET ON THE MARKET AT THE MOMENT
WHEN CORRECTLY SET UP AND CONVERGED THE PICTURE IS BRILLIANT BUT THE SET UP MUST BE DONE PROPERLY
AND THEN CHECKED ON A DAILY BASIS FOR ABOUT 10-14 DAYS
AS IT DOESN'T LIKE TO BE MOVED ABOUT A LOT
AFTER THIS PERIOD CHECKS MONTHLY SEEM TO KEEP THIS MONSTER LOOKING PRISTINE
I'TS MOST IMPORTANT THAT YOU BUY FROM A GOOD DEALER
WHO'S COMMITED TO OFFERING GOOD SERVICE NOT JUST A GOOD PRICE!! BE AWARE REAR PROJECTION SETS REQUIRE THIS SORT OF PERIODIC MAINTENENCE TO GIVE GOOD PERFORMENCE
REGARDS ROB23
Old 05-02-2002, 9:26 AM   #14 (permalink)
laurel's Avatar
Rob23
Thanks for posting - It now seems we have another member of the PT10 owners club (3 and counting). Anyone else???
I think the documentation (and Panas web site) lied about AV4 being RGB, but I'll double check tonight. Have you tried it?
By the way - you might want to tone down the CAPITALS - it's translated as SHOUTING. Should only be used in context.
Laurel
Old 05-02-2002, 1:30 PM   #15 (permalink)
jon smith's Avatar
Has been ordered (just waiting confirmation on likely delivery date) so hopefully should be here soon.
Be interested if you could check the RGB situation.
cheers, jon.
42pt10, opinions, panasonic, wanted
