Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 21-01-2006, 12:14 PM   #1 (permalink)
Thanks: Gave 1, Got 1
Lightbulb Popping Noise
Hi everyone - joined today, what a great site !!
Don't know if anyone has come accross this before...I have a Philips TV Model 28PW6515/05 (4 yrs old), in the last week everytime you change channels there is a fairly loud popping noise (sounds like it's coming from a speaker as when the sound is muted if goes).
Whether you use the remote or manually at the tv it's still the same
Any ideas please as it's slowly driving us all mad
many thanks
2stroketim is offline   Reply With Quote
Old 21-01-2006, 1:01 PM   #2 (permalink)
Conspicuous Member
JayCee's Avatar
Thanks: Gave 120, Got 855
many thanks
Your set uses the Philips A10E chassis and your problem is probably caused by the infamous "Painter" IC. (Just do a search of this forum using Painter) and you should find various messages about this model.
It's a very expensive IC and replacement inc labour usually comes in around £130.00-£150.00.
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
JayCee is offline   Reply With Quote
Old 21-01-2006, 3:23 PM   #3 (permalink)
Thanks: Gave 5, Got 9
hes correct, i have the exact same model but mines the 32" version, i had problems where the tv kept changing to EXT-1 randomly, that was over 2 months ago and its been wonderfull since then, but i can totaly relate to what ur sayin cos it drove me UP THE BLOODY WALL
ismael-1986 is offline   Reply With Quote
noise, popping
