Originally Posted by orcrist
Sorry for the delay in replying
The TV fault is picture but no sound on the terrestrial channels (sound and picture via scart are fine)
and now when the TV is switched on there is no picture or sound at all just flashing green LED light. We have to keep switching the telly on and off via the remote for it to start working. The TV repairman says we need to get the above part and he will come fit it for £15. And I dunno where to even start looking for it!
thanks
I would say you now have another fault...as well as the original fault on the Nicam board...if the part required is no longer available I'm afraid the set is un-repairable
JayCee
Panasonic Lumix DMC-G1 + 14-45mm Kit Lens.
Olympus 50mm f1.8, 135mm f2.8, 200mm f4
