Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 19-01-2006, 12:18 PM   #1 (permalink)
Question Ghosting Problems - Sony kv-36hq100b
I am having real problems with ghosting on my television. I have a sony kv-36hq100b connected to a denon dht-500sd player. I recently bought a QED scart cable recommended on this site but that doesn't seem to have made much of a difference. This doesn't happen all the time but seems to be more frequent whether or not i'm noticing it more or not, I don't know. Can anyone give me a few ideas, maybe I need to change some settings on my television? Help I'm stuck.
Thanks 4 your time!!!!!!!!!
andrew692003 is offline   Reply With Quote
Old 19-01-2006, 12:42 PM   #2 (permalink)
Thanks: Gave 0, Got 7
The term ghosting usually refers to problems related to signal quality (your aerial).
Does the problem occur when watching a video or DVD, or just ordinary TV?
Ned as much info as posible.
Nigel
nig28 is offline   Reply With Quote
Old 20-01-2006, 8:36 AM   #3 (permalink)
Most of the time its when I am watching dvd's but can sometimes happen when watching ordinary TV programs on SKY, when this happens on say BBC1 or ITV on SKY then I usually flick over to the ordinary ariel signal and the picture seems to be fine, so I'm a bit stuck really cos am a bit of a novice.
Thanks for your time!!
Old 20-01-2006, 10:51 AM   #4 (permalink)
Discribe what you are seeing, blur, fuzz, double image ect.
If you cant give a more methodical discription I sujest you wait for the fault to develop.
Nigel
Old 20-01-2006, 12:11 PM   #5 (permalink)
Usually what I see on the screen is when the picture seems to be fast moving, say an action sequence or someone or thing moving fast on the screen there seems to be a fuzzy outline and sometimes small squares that follow them around but if people are say standing still and talking there doesn't seem to be a problem.!! Hope thats enough info I can't think of anything else to tell u.
Cheers m8!
Old 20-01-2006, 3:35 PM   #6 (permalink)
Thanks: Gave 1, Got 2
Sounds normal to me!! I have this TV-what picture mode are you in? 100 Hz digital motion or the other one?! (I forget the name) What you describe sounds like the digital processing on this TV. You sometimes get a halo effect or picture break up(VERY slight) on FAST moving pictures. I also believe early models had this worse and the later ones(like mine) weren't so bad.
DRGL is offline   Reply With Quote
Old 20-01-2006, 3:37 PM   #7 (permalink)
ps,picture break up/blocking can also be caused by any transmitted digital source. DVD obviously shouldn't do it but if it's worse on Sky that would point to your dish/STB.
Old 20-01-2006, 3:49 PM   #8 (permalink)
Thanks for the advice m8. I think I am on the 100Hz anyway. Sounds like I can't do much about it which is a shame cos its a really good TV which I bought about 4 months ago from Dixons, it was a show tv and it was their last one son I got it for £650 which I think was a steal!.
Thanks 4 the help anyway, CHEERS.
Old 20-01-2006, 3:52 PM   #9 (permalink)
£650 was a VERY good price!! They were £2000,Currys onl;ine then sold them for £1600 off IIRC,i got my FS76U upgraded to one for nowt as it kept breaking down! I won't tell you how many HQ100's i got through in 12 months but touch wood this one is OK,i love the TV,great picture etc.
Old 20-01-2006, 3:53 PM   #10 (permalink)
ps,you may want to check with Sony that your TV has had the recall done-there should be a GREEN sticker(round) on the back-if not they will come out and mod. the TV!! Electric shock risk and degauss wires need tidying up.........
Old 20-01-2006, 4:06 PM   #11 (permalink)
Thanks 4 that, did not realise this so will check when I get home tonight!
Old 20-01-2006, 4:13 PM   #12 (permalink)
Just found the recall notice on the net so will have to check the TV tonight!!!
ghosting, kv36hq100b, problems, sony
