Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 18-01-2006, 6:50 PM   #1 (permalink)
Thanks: Gave 47, Got 15
Toshiba 36ZP48 Component Input !
The outer metal shielding connection of the blue component input on my 36ZP48 has come-off leaving a black coloured centre input only.
The component inputs still work perfectly but I was wondering if the component performance is in any way affected by this missing contact ?
Any comments would be appreciated.
judethedude is offline   Reply With Quote
Old 18-01-2006, 6:59 PM   #2 (permalink)
Brimstone's Avatar
Thanks: Gave 0, Got 2
The connectors outer casing is shielding and these should all be commoned at the TV input on the PCB, and as the inputs are working without it in place, they clearly are. The shielding should still be working ok as it will be connected (& commoned/joined) at the sockets (at the other end of the cable) of the DVD player or whatever signal source it is.
Long and short of it - shouldn't be a problem as far as i can see.
Just don't break off all 3 ;-)
Cheers, Brim.
Brimstone is offline   Reply With Quote
Old 18-01-2006, 7:25 PM   #3 (permalink)
Thankyou very much Brimstone.
I just wanted to know for peace of minds sake
36zp48, component, input, toshiba
