Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Old 18-01-2006, 2:24 AM   #1 (permalink)
Bulb blown in crt television ?.
I was watching my Loewe Arcada 33" crt when there was the sound of a bulb blowing followed by no picture.I checked it was not the fuse,and that is fine.Is there a bulb and does it blow and is this a major problem.Any help would be appreciated.Thankyou.
Napoleon is offline   Reply With Quote
Old 18-01-2006, 10:06 AM   #2 (permalink)
Thanks: Gave 70, Got 131
Well, there's a BIG bulb, ie the CRT, but it won't be that.
Probably an electrolytic capacitor or the line transformer if you're unlucky.
Is this a major problem? Only if you want to watch tv. A capacitor costs about a pound, a tranny about sixty, plus the cost of fitting.
sean5302 is offline   Reply With Quote
Old 18-01-2006, 11:28 AM   #3 (permalink)
Thanks for the reply.I had the transformer go about 4 months ago,and that had a different effect with a loud clicking when you turned it on(with no picture).Hopefully it is nothing too bad then.
Old 18-01-2006, 8:23 PM   #4 (permalink)
No, nothing too serious. I'm concerned at the tranny going, and now this.
Do you have power supply problems where you live? Surges, voltage dips etc?
It takes some power to blow a tranny (sorry for any gay connotations!) so I'd be looking at your wiring, both in the plug and wall sockets, seeking poor, insecure terminal connections.
Old 19-01-2006, 2:51 PM   #5 (permalink)
Everything is plugged into a Belkin surgemaster which i would hope would protect the system.There are no obvious problems with the connections;perhaps the amount of hours on the television,5500,has some relevance.Prior to the transformer going i have not had any fault with it, which is pretty good going i think.
blown, bulb, crt, television
