Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 17-01-2006, 7:44 PM   #1 (permalink)
Thanks: Gave 4, Got 16
Remote Control Erractic Behaviour!
Hi there
I've posted this over on the DVD Player forum, but seeing as this is really only a general query about remote controls, I thought I would also try posting it here as well to see if anyone can advise:-
I have a Sony DAV SB100 DVD Player (part of a home cinema set up) and just recently I have noticed that sometimes (and only sometimes) when changing the volume on the remote control, the actual player either switches off or changes the tv channel (which can be controlled via the remote - there is a little red button that lights up for tv functions)
As I say, it's not everytime, but can sometimes happen when changing volume. I am going to change the batteries today (as they haven't been changed since Dec 04 when I got the player) but my real question is:
Can batteries which are running down make the remote behave in this kind of erratic fashion? (Ie change channels/switch off when changing volume??)
I'll give it a go with the new batteries, and quite obviously time will tell, but just simply wondered if low batteries can cause this sort of thing....
Thanks in advance for any help
Paul
Paul Cooksley is offline   Reply With Quote
Old 17-01-2006, 8:01 PM   #2 (permalink)
Chris Muriel's Avatar
Thanks: Gave 185, Got 379
Low batteries could cause the problem - if the R/C has a badly designed power management supervisory system / watchdog circuitry.
I would try that first as it's an easy form of elimination.
Chris Muriel, Manchester
Chris Muriel is offline   Reply With Quote
behaviour, control, erractic, remote
