If you mean that when selecting a programme for recording via the EPG on the TV and then putting the TV into standby and hoping that Qlink will work then you might be disappointed.
I had 2 of these sets and Qlink rarely worked, sometimes it wouldn't work at all, or if it did start recording it wouldn't stop, or it would record sound without picture.
I now use the Sony STB for freeview and the manual states that Smartlink may not work all the time, I either program the video manually or use synchro record, no problems with either method.
I would get a recorder with a freeview tuner and don't bother using the TV for recording.
If your not happy you could try and get your money back.
