Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 18-12-2005, 3:39 PM   #1 (permalink)
Toddy99
Posts: n/a
Toshiba 32ZP48 Help Please
Hi Everyone,
I have just bought a new Toshiba 32ZP48.I set it up 2 days ago and am very pleased with the picture on my DVD player,but the picture through my Sky plus box is a bit grainy as if it is a poor signal.
I think I have everything set up ok,I have the sky set to rgb.Scart 1 to tv on sky plus box.The picture is ok for normal programmes but on watching the football on sky this afternoon it even looked grainy from 8 feet away.I have tried all the different setting,natural is the best the 100hz setting which is recomended for sport is slightly worse.
I have toned all the settings down as recomended on other threads,contrast 44, bright 53,colour 53,this improves the picture but watching sport is still not as good as my old 6 year old Toshiba.
I have a good scart cable fitted and have tried changing cables but the pq does not change.
I think the problem is the signal from sky.The signal quality indicator in services is ok,and I cannot work out why the picture up close was better on my old Tosh.
Any help would be very welcome
Old 18-12-2005, 7:40 PM   #2 (permalink)
slinkywonka's Avatar
Thanks: Gave 96, Got 151
If you have'nt already done so..change the sharpness to -20.that helps alot and reduces the blocky effect.I have no 'grainy' pic,just some channels look a little blocky like ITV (crap)
Heres my settings for sky:
Colour: 38
Contrast: 49
Brightness: 62
sharpness: -20
Tint: 0
Colour Temp: Normal
Scan Mode: Progressive
Black Stretch: OFF
slinkywonka is offline   Reply With Quote
Old 18-12-2005, 9:11 PM   #3 (permalink)
houdini_7's Avatar
Thanks: Gave 50, Got 31
i know exactly what you mean, with regard to watching live sport.
I have the 36ZP48 and i noticed the grainy effect...but I recently upgraded from Sky Digital to Sky + and the PQ has improved ten fold, not sure whether it was the connection from the dish but the problem has completely gone away.
houdini_7 is offline   Reply With Quote
Old 18-12-2005, 10:05 PM   #4 (permalink)
Toddy99
Posts: n/a
Thanks for replying,
I have Sky plus and the picture is still quite grainy close up,and even from normal viewing distance on some channels.
I have the settings about the same as suggested except mine are on normal mode as the others are even worse, is there anything I can do to improve this as I mainly watch sport and I think the picture was better on my old Telly
for sport.
Is there anything I can do to get a better reception from Sky and my pq would improve.
Thanks Again
Old 19-12-2005, 8:36 AM   #5 (permalink)
houdini_7's Avatar
As i said i'm not actually sure what prompted the improvement in PQ from the Sky + installation. One thing the engineer did do was put new connectors on the cable coming from the dish as he said they weren't done very well.
How old is your Sky + box?
Old 19-12-2005, 12:40 PM   #6 (permalink)
Toddy99
Posts: n/a
My sky plus box is about 3 months old.The reception seemed ok with my old tv,but I wonder if it is because the new one is better quality the poorer reception shows up more,if that makes sense.
Old 19-12-2005, 2:39 PM   #7 (permalink)
houdini_7's Avatar
How high are your signal strength bars etc on your sky + box?
Old 19-12-2005, 5:08 PM   #8 (permalink)
Toddy99
Posts: n/a
The signal strength is just past halfway and the quality is three quarters up.
32zp48, toshiba
