Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Connections advice? Ozgeoff DVD and Blu-ray Recorders, Recording and Media 2 17-08-2004 1:34 PM
3 sata drives and only 2 sata connections! Cameron Computer Systems 2 02-07-2004 9:59 AM
Audio and Video connections through Amp Malkyboy AV Amplifiers and Receivers 0 25-01-2004 4:04 PM
Toshiba Component Video Connections - HELP!!!! mrsingh CRT Televisions 8 18-01-2002 1:12 PM
Toshiba Component Video Connections - HELP!!!! mrsingh DVD Players 2 30-08-2001 3:14 AM
Old 04-01-2002, 12:11 AM   #1 (permalink)
Question Help with connections
I have a Goodmans dvd home cinema system, the chap at the shop told me I would be able to play the normal telly programs through the front left and right speakers by just using scart connections but it dosen't.
I have one scart from telly to DVD, one scart from telly to VCR and another scart from VCR to sky digi box.
I can get normal telly sound through the speakers if I connect the DVD to telly with the two audio out jack plugs but I am thinking of buying a wide screen telly and the ones I have looked at don't seem to have the two stereo audio out connections.
curlywatts is offline   Reply With Quote
Old 04-01-2002, 1:05 PM   #2 (permalink)
M.Joshi's Avatar
Thanks: Gave 0, Got 9
Arrow Audio output.
Most t.v manufacturers now provide separate audio out connections on the rear of the t.v. If not, you can always use a SCART - 2RCA lead to connect to your Goodmans Hi-Fi.
M.Joshi is offline   Reply With Quote
Old 04-01-2002, 4:58 PM   #3 (permalink)
Doubledoom
Posts: n/a
adapt the usual response given below to suit your set-up. Note the 2x phono from the tv to the amp to carry the tv audio.
Various ways to connect depending on what you think is acceptable.
option 1 - RGB for both DVD and digibox but need to record via the RF.
Audio carried from TV to Amp and DVD to amp (TV passes audio from vcr and
digibox)
DVD > Digibox VCR scart ( use scart lead, set DVD to output RGB)
Digibox > TV (use scart lead into RGB scart socket)
Video > TV (scart lead into composite scart socket - Don't use an expensive cable, it would be wasted)
Aerial > digibox > vcr > TV
DVD > Amp (using digital co-ax or optical -identical quality, depends on your available connections)
TV > Amp (using 2x phono connection)
Option 2 - RGB for digibox and s-video for DVD. Allows recording via the scart. Audio the same as above
DVD > TV (scart into s-video scart)
Digibox > TV (scart into RGB scart)
Digibox > VCR (composite scart - Don't use expensive cable for this one)
Option 3 - TV doesn't pass audio or doesn't pass it with decent quality. Will require manual switching between sources. Use video connections as option 1 or 2.
VCR > Amp (using 2x phono connection)
Digibox > Amp (using 2x phono connection)
connections
