15-12-2005, 6:21 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 49, Got 51 | 32 inch with £450 to spend
I am looking for a 32" TV for my mum for xmas but only have 450 to 500 to spend.
Can you recommend any thing
Cheers Darko
Home Cinema = Harman Kardon avr335 Anthony Gallo Nucleus Micro 5.1, sammy 32 inch LCD R7. pioneer PDP506XDE .Toshiba HD-E1 Hd-dvd player Sammy Blu Ray player,Harmony 1000
Laptop = Black Macbook (2 Gig Crucial)
Watching=V (2009) woop
15-12-2005, 9:33 PM
#2 (permalink)
| | Senior Member
Well Cheers Gents for the help I will start scanning the net
Darko
15-12-2005, 11:21 PM
#3 (permalink)
| | Member
Thanks: Gave 68, Got 17 | Quote: |
Originally Posted by Darko Well Cheers Gents for the help I will start scanning the net
Darko |
hi let me know if you have any luck!
i am looking for the same!
looking for a 100hz tho!
currys had a good deal on, i missed out though and apparently it's discontinued, but it retails for £600 but currys had it for £379 and if you use discount codes you get it cheaper...try it against your post code you might hit lucky... http://www.currys.co.uk/martprd/stor...g_page=Product
edit:
i have just tried it again and it worked for me this time... i have put my order in
15-12-2005, 11:29 PM
#4 (permalink)
| | Senior Member
Hey bud
I scoped out a few the fit the hole but cant find any info on them
Sony kv32cs71
Toshiba 32zh36
both from Webelectricals.co.uk
Have a look and tell us what you think
Cheers Darko
15-12-2005, 11:39 PM
#5 (permalink)
| | Member
Thanks: Gave 5, Got 9 |
go for the sony mate has an EXCELLENT Trinitron picture tube, ill admit Toshiba are good but u cant beat a good sony......... |
15-12-2005, 11:42 PM
#6 (permalink)
| | Senior Member
my lord I got some advice from the CRT boys
Cheers Mate I will do I will order it tomorrow( Its only for my dear old mum for xmas)
Thanks for the advice
Darko
15-12-2005, 11:43 PM
#7 (permalink)
| | Member
they both look nice to me, but the sony doesnt come with a stand, toshiba does..but it seems the sony has an extra scart and also s-video connection
both look good to me though
check out that panasonic that i mentioned http://www.currys.co.uk/martprd/stor...g_page=Product |
15-12-2005, 11:51 PM
#8 (permalink)
| | Senior Member
Yup I saw this one but this forum have way too many mixed opinions on Panasonic and the model before this one the Panasonic TX-28PM11 was a bit of a turkey.
So I think I will settle for sony ...never bought one before as I usally go for Toshiba. But as I said its for Mum so we will try Sony
Cheers Darko
19-12-2005, 6:00 PM
#9 (permalink)
| | Senior Member
Well I went ahead and ordered a Sony kv32cs71 last Thursday from Webelectricals.com ( I think that was the name) and it arrived today and my Mum is well pleased, The picture was very good lets just see if it stands the test of time.
PS the box was massive
Cheers Darko
also the tv was 450 delivered
19-12-2005, 6:21 PM
#10 (permalink)
| | Member
Thanks: Gave 0, Got 1 | |
19-12-2005, 8:38 PM
#11 (permalink)
| | Senior Member
cheers Bud but as you can see I purchased one already
Cheers Darko
20-12-2005, 11:39 AM
#12 (permalink)
| | Member
ah no sweat bud.
sorry for not reading all the thread. |
20-12-2005, 2:18 PM
#13 (permalink)
| | Member
same with my mum the last 3 televesions shes had in the house since when i was born in 86 wear all toshiba then about 4 yrs ago she upgraded to a 4:3 29" SONY FD WEGA my god its loverly still going strong........
hope ur mum likes it after all the trouble you'v gone to
