Sony DX200 backend settings
Hi folks,
Can people with the DX200 (and DX150 and NX200 which it seems are also AE6D chassis) post their values for RGB drive and cutoff from the backend section of the service menu? Particularly if you've ever adjusted them.
I realise it will be different for each set, but mine seems to have an odd pinkish hue to reds (compared to my previous Trinitron - I don't know which one is right though).
Faces are a bit ruddy ('red push'?).
Mine are:
RGB drive 30,21,21
RGB cut 31,25,26
Taking down the red cut to 26 and lifting green drive up to 24 seems better balanced but still not quite right. I have the DVE disk.
Thanks!
