| Horizontal lines on Sony KV28CS70
Apologies in advance from a newbie, but folks advice would be appreciated....
...I bought a Sony KV28CS70 widescreen CRT and hooked it up to a cable box (RGB), DVD (RGB) and VCR (AV) via individual scart leads. On all 3 sources, there were 2 "blank" horizontal lines noticeable when you were close to the screen (one approx. 1/3 of the way down the screen and the other about 2/3 of the way down the screen). The screen would occassionally "flicker" in these areas, depending on the picture being shown (which is what drew our attention to the problem in the first place). Anyhoo, retailer came out to see problem and arranged a swap no problem. However, the second set is doing exactly the same thing! Given that these "dead" lines appear on-screen regardless of the input source - am I right in assuming the TVs at fault? Am I being unreasonable and expecting too much of a CRT picture (i.e. it is common to get horizontal lines appearing on a widescreen CRT due to the size of screen)? What would people consider a reasonable number of replacement sets to accept before demanding a refund, as it's a lot of hassle each time?
