Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Who makes - 14" or 15" Nicam stereo TV's (preferably flatscreen)? piknik CRT Televisions 3 25-05-2003 12:01 AM
Nicam sound from Cable - I think not ! mwhorley Satellite TV 2 26-02-2002 11:45 AM
DPL and Nicam clearups John R Baker AV Amplifiers and Receivers 2 26-01-2002 11:57 AM
FM Arial on Denon 3802... Desticado AV Amplifiers and Receivers 9 15-01-2002 12:08 PM
under 1000 for a good tv nicam raymandust CRT Televisions 0 19-11-2001 9:34 AM
Old 22-11-2001, 5:14 PM   #1 (permalink)
graham.myers
Posts: n/a
nicam thorugh an arial
When a terrestrial channel transmits a nicam signal to your TV, it decodes it and gives you stereo.
When you add a video, the RF cable is plugged into the VCR and a fly lead to the TV. The video will pass the nicam signal to the TV and so you can watch to nicam program on UHF rather than having the VCR turned on and the TV AV1 selected.
In a collegues VCR manual it says *during playback* to listen to nicam sound you must use a scart connecter.
Why is that?
Old 22-11-2001, 5:42 PM   #2 (permalink)
Gordon @ Convergent AV's Avatar
Thanks: Gave 567, Got 1,191
It's because the rf loop through to the TV is carrying the, already encoded, NICAM broadcast signal from the broadcaster.
The video and satellite boxes for that matter do not have NICAM modulators built in to them to encode stereo sound from a tape in to the RF output. This is done for cost reasons I'd guess.
If you look around you'll find plenty of mono rf modulators but not many NICAM ones.
Gordon
My Photos: Flickr
Blog with some of my pics on it
Gordon @ Convergent AV is offline   Reply With Quote
Old 23-11-2001, 9:12 AM   #3 (permalink)
graham.myers
Posts: n/a
[/B][i]satellite boxes for that matter do not have NICAM modulators built in to them to encode stereo sound from ... in to the RF output. This is done for cost reasons I'd guess.
[/B]
thanks for the reply Gordon. Does this mean you also have to have a scart connection to get NICAM from Sky too. This means on Sky's digibox the second RF feed doesn't transmit a NICAM signal.
That puts the mockers on my satellite around the house project :-( I was going to use the RF feed into my cinema room. Ah well rethink time.
thanks again
Old 23-11-2001, 4:14 PM   #4 (permalink)
Doesn't matter whether it's RF1 or RF2 you still wont get NICAM out of a satellite box that way. You need a nicam modulator to feed the l/r audio and compositre video to for distribution around the house. Or you can just make a long scart to 3 phono lead from the box to the av amp
You could also look at sending the l/r/ audio and video down a length of CAT5 using some wee boxes I know of to drive the signal.
Gordon
My Photos: Flickr
arial, nicam, thorugh
