Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Help white ghosting on my Toshiba 32Z23 mackemansj1 CRT Televisions 0 31-01-2004 8:31 AM
Toshiba 15" 5V11B TV Product Recall nathan_silly CRT Televisions 0 19-07-2003 6:57 PM
Someone advise me of my rights (Robertsons and Toshiba) Logan CRT Televisions 17 06-06-2003 2:49 AM
ex display plasmas/projedtors lab Home Cinema Hardware Bargains and Discount Codes 0 02-02-2003 2:07 PM
More Toshiba Rubbish: Will I Never Learn Meldrew_Lives CRT Televisions 19 12-01-2002 3:00 PM
Old 22-11-2001, 4:13 PM   #1 (permalink)
gedclink
Posts: n/a
Question Ghosting on new Toshiba 50" RP
Toshiba 50Wh18b.
Generally really happy with this tv but am unsure as to whether the signal or telly is to blame with several problem..
1) Fast moving objects such as action movies etc leave a ghost image for a split second...I was watching stargate last night on sky 1 and it appeared that there were around 2 or 3 images on screen as some daft actor did a commando roll on screen..
I've tried playing with the 100 HZ scan and Digital Noise Reduction but it doesn't appear to change anything.
2) Once again ( on telewest digital cable ), if I turn up the contrast or brightness the picture looks goddamn awful..
LOTS of shimmery white lines all over the darker scenes..Almost looks like interference from the mains but I've switched all other things off? The only way I've found is to keep the contrast and brightness well down at around 35 - 40 ( 0 - 100 )
3) Not hugely problematic but areas of brightness or large expanses of white tend to " bloom " into the darker areas.
Still to really check this out on DVD..
Although the telewest input is digital, could it still be the main contributor to the above problems..
Old 22-11-2001, 7:38 PM   #2 (permalink)
Kirthen
Posts: n/a
I am sorry to hear of your Tosh problems, I expect its Telewest. But you will only know when the DVD is connected.
I replaced my Grundig 37" CRT with the 50WH18 about a month ago. The picture quality has been perfect and I mean perfect - as long as the source material is up to it ie. DVD fed by component/RGB! Definitely superior to the Grundig.
The quality of Sky Digital has varied from very good to excellent, but again rubbish in, rubbish out. Talking of rubbish - terrestrial analogue, just plain grainy - but no worst than when viewed on the big old Grundig.
There is no ghosting, white lines or bloom on any digital input. My settings are Contrast 49, Brightness 55, Colour 50, Sharpness 0.
Lastly, where is your Free Tosh DVD Player (SD-110E) with component outputs - I thought this was a Tosh promotion for all WH18s?
I hope you get it sorted - there is a good tele in there.
Kirthen
Old 22-11-2001, 10:46 PM   #3 (permalink)
Thanks: Gave 21, Got 42
Ged,
I agree with Kirthen it may be hard to nail this down until you have a known good quality reference point.
If you do have a DVD feed available it would be worth getting hold of a copy of DVD Essentials, Avia or similar
Or at least a disk containing the THX optimode set-up utility (Episode 1, fight club both have this, possibly others) that will let you get your user settings into the right ball park.
I certainly noticed an immense improvement in image quality having run through the set-up routines in DVD Essentials.
Although it took a day or two to get used to the new look, the preset look overly bright and garish now,
As reference my settings are:
Contrast 24
Brightness 46
Colour 56
Tint 0
Sharpness -30
Although I suspect that the exact setting will not produce the same results from set to set.
It may also be worth trying your own settings based on the different presets.
From other posts I’ve read it appears that different features are enabled / disabled outside of user control depending on which preset was selected when making your personal settings.
I have mine based on preset –3 which I believe disables scan velocity modulation.
mseabroo is offline   Reply With Quote
Old 23-11-2001, 8:55 AM   #4 (permalink)
gedclink
Posts: n/a
Telly and DVD Player
The DVD player should arrive today or tomorrow.
They were out of stock when the tv was delivered.
I'll let you all know ( hopefully good ) news after the weekend.
Have a nice one.
Regards
Ged
Old 27-11-2001, 4:27 PM   #5 (permalink)
gedclink
Posts: n/a
Good advice
Once I'd connected up the DVD via component leads the picture was excellent..I've also noticed that the picture quality is dependant upon different channels via telewest..i.e
Sky 1 is pretty rank but Channel 5 is spot on..
Also, anything originally taped in NTSC i.e sopranos on E4 or channel 4 appears to be of a better resolution than " normal "
PAL recordings.??
Thanks for the help
Ged
