The menu can be accessed using a remote control sequence - as published on many 'sites' (just dont have it to hand)
But beware.
This set is very different to others. Although many menu options will be the same, the LCD engine has several different settings that are not so obvious !
If you get there and experiment, then publish you results please ! but the usual warnings about recording settings and taking care on the TT menu remain.
Why do you want to get into the eng settings ?
Good Luck
Russ
