Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Need advice on a new widescreen TV Weinberg CRT Televisions 3 08-01-2004 10:11 PM
Starting out - screen and Z2 questions. topperdoggle Projectors 2 04-01-2004 11:11 PM
16:9 widescreen or 4:3 screen? iMan Projectors 6 23-11-2003 10:58 PM
Distortion on widescreen tv's - is this normal? videoman CRT Televisions 6 17-06-2002 12:30 AM
CRT screen calcs. ANSI or Peak? Nic Rhodes Projectors 9 30-09-2001 9:11 PM
Old 20-11-2001, 10:41 PM   #1 (permalink)
simonwa
Posts: n/a
Angry Widescreen screen distortion
I am fairly new to the world of widescreen and was wondering if anyone could give me any advice. I own a Philips 28pw6615. In all modes i.e tv, DVD, playstation I am getting a slightly distorted display shape. The screen on the left hooks off and down at the edge of the screen and the left hand edge is slightly concave, whilst the right hand side is perfectly aligned. This is most noticeable when using a playstation due to the black border around the display area and various game menus which are symmetrically presented - highlighting the "bent" display area, though the problem is with any form of display. I was wondering if a bit of screen warping like this is fairly normal/acceptable, or whether I should have a clearly symmetrical presentation? The tv got fantastic reviews and I would have thought by now this problem wouldn't really exist. Also, when using 50/50 teletext and tv mode ( ie vertical split) the teletext is so out of focus at the edge of the screen that it is barely ledgible. Are these normal problems or should I have it looked at? Any feedback would be geatly appreciated.
Old 21-11-2001, 8:57 AM   #2 (permalink)
Super Moderator
Thanks: Gave 464, Got 946
Ahhh....the joys of Cathode Ray Tubes.
You should be able to get this adjusted; presumably it's under warranty. Most TVs have adjustments of this sort in an engineer's menu, although the extent to which the problems you describe can be electronically adjusted out will depend on the mechanical contruction of the tube - if it's too far out, it may not be possible to get it close to perfect. You can only get an engineer to try for you (or do it yourself if you are brave and know the access code for the menu).
Why is it that PC monitor manufacturers nearly always offer a comprehensive range of geometry adjustments, yet leave these controls off the user menus in TVs?
Nigel
Except on matters of forum moderation, the views expressed in this post are my own, and do not necessarily reflect the opinions of AVForums.
LV426 is offline   Reply With Quote
Old 25-11-2001, 4:12 PM   #3 (permalink)
warryor
Posts: n/a
Because monitor customers are a lot more likely to care about quality, noone would accept a totally distorted Excel spreadsheet, but a fast moving episode of "Xena" is not likely to show defects much. =)
Also I would think monitor buyers are more technical than TV buyers, in general.....
Yeah, that's probably how the manufacturers think, or something along those lines. =)
(I don't really know, but still I think it sucks bigtime... but what can you do? Buy a plasma.... yeah right!)
distortion, screen, widescreen
