Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
My Bloody Valentine - Special Edition Blu-ray ReviewTerminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD Review
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Sony Video Upconvert Problem Fat Arnie AV Amplifiers and Receivers 0 09-07-2004 7:39 PM
Problem on Sony KV-28FQ70 rembang CRT Televisions 0 22-04-2004 8:10 AM
Sony STR-DB940 Problem - any ideas? Steve Zodiac AV Amplifiers and Receivers 8 07-02-2004 7:54 PM
Sony KV32FQ75 - Continuing Problem fwan CRT Televisions 86 27-09-2002 1:34 PM
Sony 36" widescreen purple tint problem dpiper CRT Televisions 2 15-05-2002 9:23 PM
Old 26-10-2005, 3:22 PM   #1 (permalink)
Thanks: Gave 7, Got 1
Sony 28" FQ75 problem
Hi.
Has anyone experienced the same problem as me and even better, know of a fix??
Basically, when watching a really light scene on the TV, you can just about make out two parrallel lines running aggross the screen, say about 3 inches from the top & bottom of the screen. It's not really too much of an isse but bugs me nevertheless!!
Thanks in anticipation,
Simon
sbaddison is offline   Reply With Quote
Old 26-10-2005, 3:25 PM   #2 (permalink)
is it when you have black bar cinemascope format
ricco10 is offline   Reply With Quote
Old 26-10-2005, 3:45 PM   #3 (permalink)
Hi.
No. They are lower / higher than where the black bars are or would be
Cheers,
Simon
Old 26-10-2005, 5:07 PM   #4 (permalink)
take a picture if you can and attach it on this post
Old 26-10-2005, 6:37 PM   #5 (permalink)
Most likely they are the horizontal wires supporting the aperture grille, they are usually visible in Trinitron sets.
topdude is offline   Reply With Quote
Old 26-10-2005, 6:40 PM   #6 (permalink)
Thanks: Gave 0, Got 7
They can be seen (horizontal wires supporting the aperture grille), usually if you look very hard. Once you have seen them it seems alot worse.
Most people do not notice them.
Nigel
nig28 is offline   Reply With Quote
Old 28-10-2005, 4:18 PM   #7 (permalink)
dsb
does this forum hold archives going back a few years?
this was big news back then - a design fault, nasty scrolling bars.
i had to threaten court action to get a refund for mine - apparently there was some kind of fix released later on but i couldnt say for sure.
presumably your tv will be well out of warranty by now so you may have to put up with it.
Gareth.
that fly....is your magic wand.
dsb is offline   Reply With Quote
fq75, problem, sony 28
