Go Back   AVForums.com > Video Electronics > CRT Televisions
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
ex display plasmas/projedtors lab Home Cinema Hardware Bargains and Discount Codes 0 02-02-2003 2:07 PM
Toshiba 46WH08B Designer menu settings Littlemule CRT Televisions 8 18-10-2001 9:50 AM
Sony KP44PS2 or Toshiba 46WH08B Graham Sims CRT Televisions 0 30-09-2001 10:10 PM
TOSHIBA 46WH08B CONVERVERGENCE charles CRT Televisions 4 08-07-2001 10:52 AM
Old 18-11-2001, 5:24 PM   #1 (permalink)
Bri
Posts: n/a
Toshiba 46WH08B
I have just got this set and have noticed a faint pink and then green band that runs from the top to bottom of the left hand side of the screen. It starts with a pink colour about an inch wide, then green which is about 3 inches wide , then there is pink and green again though these two strips are much less noticeable.
I have searched through this forum and followed the general advice but with no success. I have let the set warm-up and set the convergence, I have also moved my speakers and amplifier and sky box out of the room just in case they were intefering with the picture but it made no difference. At the moment I just have my DVD connected via components.
I have adjusted the colour, and turned down the contrsast but still these lines persist.
Have I overlooked anything or is it time to call Toshiba?.
The rest of the picture is superb, especially from DVD, by the way.
Old 18-11-2001, 8:47 PM   #2 (permalink)
Thanks: Gave 131, Got 3
Bri,
How did you set the convergence?? User or service mode??
Regards
Shady Deal is offline   Reply With Quote
Old 18-11-2001, 9:49 PM   #3 (permalink)
Bri
Posts: n/a
I set it up via the user mode. I don't know how to access the service mode. Is it something I should attempt or is it diffucult to do?.
Thanks for the reply.
Old 18-11-2001, 11:03 PM   #4 (permalink)
Bri,
All the Tosh Rp seem to have slight bands down the left hand side (Mine does!!) but these are of a "Grey" colour and only noticeable on some backgrounds.
However, I would definately say that your convergence is out and needs to be done in the service mode.
I had a similar type of problem with my set when it first arrived even though the user convergence was smack on. it turned out that even though the convergence was correct in the areas that the crosses are, that parts of the screen between them were well out.
See the thread running on the forum at the moment regardin the 50" Tosh on how to enter the service menu and convergence screens.
This is not a hard thing to do and will give you an amazing picture as you can just about get all the screens "Perfect" with time.
Be warned however, by entering the service mode on any Tv set you run the risk of messing up your Tv completely, so if you are not confident get an engineer out.
If you still want to have a go and are confused by the tread I refer to above, E-Mail me off list and I will try and walk you through it.
Regards
46wh08b, toshiba
